Need help with two problems. Hard to start and seat issue.
Old Mar 28, 2010 | 11:42 PM
jnharold's Avatar
jnharold
Cruising
Default Need help with two problems. Hard to start and seat issue.
I have a 04 6 speed coupe. First problem is to start the car either I have to turn the engine over for 5-10 seconds or turn it over 2-3 times quickly to get it to fire up. When it fires it runs great but I just can't get in and turn the key and have it fire right up? This is a daily driver and I replaced the battery and have used many tanks of gas with additives so I don't think it was a bad tank of gas. The other problem is while driving the seat will reposition it's self like I am trying to adjust it. It goes to the same position every time which is a movement where it tilts back and puts my knees in the dash. Not good while driving. It doesn't happen every time I drive but like I said it's a dd and happens about every other week. Thanks for any help with either problem.
Old Mar 29, 2010 | 08:10 AM
Z06_BluByU's Avatar
Z06_BluByU
have ya pulled the code yet? what codes is it flashing? Whats the fuel pressure at the rail? Last time the fuel filter was changed?
Old Mar 29, 2010 | 10:48 PM
jnharold's Avatar
jnharold
Cruising
No codes. Fuel filter on a 2004 is in the tank. Supposed to last forever I guess? Only 44K miles. I have not checked the fuel pressure. Had someone tell me it may be the oil pressure sensor/switch. Would that cause a delayed start?
Old Mar 29, 2010 | 11:15 PM
lucky131969's Avatar
lucky131969
For sure. Need to know what pressure you have at the rail, and if there is any bleed down.
Old Mar 29, 2010 | 11:32 PM
jnharold's Avatar
jnharold
Cruising
If fuel pressure is low wouldn't it run bad. After It gets started it runs great like nothing is wrong.
Old Mar 30, 2010 | 12:07 AM
lucky131969
It's not about low "running" pressure, as it is about "starting pressure". If you have a bad check valve in the pump assembly, leaky injector, etc.....the pressure will bleed down...and hard start.
Check the pressure at the rail/bleed down.
To Need help with two problems. Hard to start and seat issue.
