Trunk Won't Open
Old Mar 29, 2010 | 01:53 PM
realvc's Avatar
realvc
Default Trunk Won't Open
The trunk on my 99 vert won't open using the fob or the switch in the dash. The car was running in neutral (6spd) with the parking brake set. The tonnoue cover is closed and latched but the trunk still will not open.Using the owners manual I have not found where the fuse would be to check it.
Where is the fuse or where should I check?
Old Mar 29, 2010 | 02:04 PM
cliff_ford's Avatar
cliff_ford
Fuse 26 in the pasenger foot well.
Old Mar 29, 2010 | 05:58 PM
realvc's Avatar
realvc
Thanks, I see it now. I don't know why I could not see it before. I just thought I was reading the owners manual.
Thanks again. I'll check it this evening when I get home.
Old Mar 29, 2010 | 06:31 PM
bobby777's Avatar
bobby777
If the fuse doesnt work--take a screw driver and hammer--wedge the screw driver in and pull up hard--usually will give--good luck-
Old Mar 29, 2010 | 06:34 PM
lucky131969's Avatar
lucky131969
Old Mar 30, 2010 | 10:21 AM
realvc's Avatar
realvc
It healed itself. It now works with the fob or the dash button.
Sure am glad I did not have to use a screw driver to pry it open like bobby777 suggested.
Old Mar 30, 2010 | 02:06 PM
bobby777's Avatar
bobby777
So sorry--I had brain fade--I was thinking of my uncles family car--1949 Hudson Hornet
Old Mar 30, 2010 | 03:13 PM
blue63cpe's Avatar
blue63cpe
When the car is running it will not let you open the trunk, fob or button. It "healed" it self because the car was turned off.
Old Mar 31, 2010 | 11:14 AM
Jewjenk's Avatar
Jewjenk
----------------USER ERROR------------------
To Trunk Won't Open
