Fob Gremlins and More
Old Apr 1, 2010 | 02:57 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Fob Gremlins and More
Been a while since I've made it into the C5 forums. A buddy picked up an '00 A4 and I've been driving it around tuning it for him. One big problem it's got is that even though the fob is not set to passive it honks at various times when walking up to it, walking away from it, standing next to it or sitting in it. Basically if you're in or around it without the ignition on it will randomly honk. Even weirder is that even though it honks when you leave it does not lock...
I don't remember having any problems with my old '99 or seeing threads on it. Any thoughts? Mine is that maybe another fob is hidden somewhere in the car.
Old Apr 1, 2010 | 04:01 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
'00-'04 do not have the passive feature. Are you sure it's an '01?
Old Apr 1, 2010 | 04:02 PM
5 Liter Eater
St. Jude Donor '11
Hmmm. Now that you mention it I do remember passive going away in the later C5 years. The fob has the passive switch, could it be a <'99 fob and using it on a 2000 is causing a problem?
Old Apr 1, 2010 | 04:05 PM
Mark C5's Avatar
Mark C5
No, an earlier FOB would work on a 2000 but it would not activate any passive features because the '00-'04's did not have them. If the FOB has a switch and it activates passive features, the car is a '97-'99.
Also, if you've been having trouble tuning the car, this would explain a lot.
Old Apr 1, 2010 | 04:22 PM
5 Liter Eater
St. Jude Donor '11
Actuall the car seems to react the same whether the fob is set to passive on or off. No problems tuning it. It reads and writes fine. HPT sees it at a 2000.
Old Apr 1, 2010 | 04:26 PM
Mark C5's Avatar
Mark C5
You might want to contact Gene Culley at www.gmpartshouse.com and have him run the VIN. It sounds to me like the car is a '99.
Or you can do it yourself. Look at the 10th character in the VIN.
W= '98
X= '99
Y= '00
1= '01
Old Apr 1, 2010 | 04:32 PM
5 Liter Eater
St. Jude Donor '11
I ran the VIN through http://www.decodethis.com/ and http://corvettelink.net/vindecoder.asp and both show it to be a 2000.
Old Apr 1, 2010 | 04:50 PM
Mark C5's Avatar
Mark C5
Never heard of this before. I wonder why it has the '97-'99 FOB? If you switch to the 2000 FOB then the passive can't work no matter what year the car is.
Old Apr 1, 2010 | 04:51 PM
RDKING's Avatar
RDKING
I had a 2000 and it had a passive FOB ?????
Old Apr 1, 2010 | 05:04 PM
Mark C5's Avatar
Mark C5
The FOB for the 2000 does not have the passive on/off switch that the '97-'99's have.
Old Apr 1, 2010 | 07:35 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
its possible it could be a transitional car built in Nov , Dec 99 but still a 2000 on paper. If the car came with Passive fobs the receiver is a 99 also, look at the build date...on the driver door, it may be titled as an 00 but someone dropped the ball somewhere. The Vin could be wrong also, or could point to it being a 99, same as the door...
Old Apr 1, 2010 | 07:37 PM
RDKING's Avatar
RDKING
Mine did
Old Apr 1, 2010 | 07:50 PM
RDKING's Avatar
RDKING
My 1999 FRC does not have a passive on/off switch.
Old Apr 1, 2010 | 08:16 PM
Mark C5's Avatar
Mark C5
There are three FOB's for a C5. '97-'99 has a passive on/off switch, '00 operates on the same frequency as the '97-99 but does not have the passive on/off switch and the '01-04 which do not have the switch and operate on a different frequency than the '97-'00.
As Evil- Twin said it is possible to have a 2000 that is a transitional model built in Nov-Dec '99 which would still have the passive feature and the early FOB.
If you have a '97-'99 with a FOB that does not have the switch, someone has replaced the original FOB with a 2000. This is very common because they cost considerably less and most people do not use the passive entry system due to the problems mentioned in the OP's first post.
Old Apr 2, 2010 | 10:14 AM
5 Liter Eater
St. Jude Donor '11
OK, so I cracked it open and cleaned off the contacts which necessitated me re-pairing the FOB and now it is much better. So now if the FOB has passive disabled there is no honking at all. If it's enabled it only honks once when it gets out of range and does not honk when I come back into range as I would expect. However; It still does not lock when it honks in passive mode. You can open the door and the alarm goes off.
Old Apr 2, 2010 | 10:43 AM
Mark C5's Avatar
Mark C5
Sounds like it must be one of those transitional models Evil-Twin was talking about
Old Apr 2, 2010 | 10:51 AM
5 Liter Eater
St. Jude Donor '11
I guess so. I just wonder why it's not locking when it arms/honks when set to passive. My buddy would actually like to leave passive disabled so he'll be happy with it not randomly honking regardless of the FOB mode but it bugs me.
Thanks for everyone's input.
Old Apr 2, 2010 | 10:58 AM
Evil-Twin's Avatar
Evil-Twin
you should be able to turn off the horn in the last group of options found in the set up on your DIC.
Old Apr 2, 2010 | 11:33 AM
5 Liter Eater
St. Jude Donor '11
Yea I know but then it's still not locked. Turning the FOB to non-passive and manually locking and unlocking is what he wants so it's all good. Before it would honk randomly whether the FOB was on active or passive.
To Fob Gremlins and More
