HID light problems - no help w/ search
Old Apr 1, 2010 | 05:42 PM
Spikehorn's Avatar
Spikehorn
Default HID light problems - no help w/ search
Anyone ever have a problem with their HID lights after they take their car out of storage?
I got my car out today and for some reason turned on the lights. When the lights came on, they were both blinking fast, one came on and stayed on, the other went out. I have a HID conversion for my low beams. I know they worked properly when I put the car away last fall.
Any Ideas?
Thanks,
Scott
Old Apr 2, 2010 | 12:23 PM
UncleFodder's Avatar
UncleFodder
Any Ideas?
Thanks,
Scott
This will happen on mine if the voltage is too low, like a strobing effect. What does your voltage meter show?
Old Apr 2, 2010 | 04:17 PM
Spikehorn's Avatar
Spikehorn
The voltage shows 13 with the car running. However, I turned the lights on with the car not running. It looks like the voltage is less with the car off.
I think I need to disconnect and reconnect the battery, will that help?
Old Apr 2, 2010 | 04:47 PM
jc227's Avatar
jc227
Run your car a little so your battery gets charged back up then try again.
Old Apr 2, 2010 | 05:00 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Get the battery charge up to where it belongs first.
Old Apr 3, 2010 | 10:57 AM
rws.1's Avatar
rws.1
low voltage can cause all sorts of gremlins...
You should keep your Vette on a battery float charger while in storage
To HID light problems - no help w/ search
