Problems with the Radio and Seat
Old Apr 3, 2010 | 07:42 PM
ZAXVETTE's Avatar
ZAXVETTE
Default Problems with the Radio and Seat
Hey Guys,
Trying to fix an issue with a Corvette, my father left the windows down during a rain storm and now the radio and Front seat do not work. (Seat continually wants to go forward. I have looked at the fuses (all good) and I have even replaced the little black box under the seat a nice 200 dollar wasted... Any ideas of what it could be would be appreciated. Oh and the radio is completely dead, no time displayed, nothing.
Thank you in advance
Zach
Old Apr 3, 2010 | 11:22 PM
ZAXVETTE's Avatar
ZAXVETTE
Thinking it should be the same issue but am not sure...could it be a coincedence? Should I pull the radio is there some secret fuse somewhere?
Old Apr 4, 2010 | 10:30 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Pull your codes. I'll guess that you'll see some "NO Comms" messages. I suggest disconnecting one system at a time such as the door control modules, then seat module. Look for water in or on the BCM which is in the passenger footwell.
Old Apr 4, 2010 | 12:14 PM
ZAXVETTE's Avatar
ZAXVETTE
Okay no codes on the BCM but I have these codes
Radio No Com.
Aoldcm
b2282h
b2284h
b1064h
A1Rdcm
B2283h
b2285h
U1064h
BO-Rfa
U1096h
U1064h
u1016h
I know a couple of these say no communication with the BCM, does that mean the BCM is bad?
Old Apr 4, 2010 | 01:10 PM
postwhore's Avatar
postwhore
no,those are common
I would have diconnected the battery and got fans on it to dry everything out 1rst
Old Apr 4, 2010 | 01:25 PM
dgrant3830's Avatar
dgrant3830
Try disconnecting the LDCM, then the RDCM and see if the radio comes to life. This will eliminate them from being the cause or verify that one or more is causing issues.
Old Apr 4, 2010 | 05:13 PM
ZAXVETTE's Avatar
ZAXVETTE
It's all dry, this has been like this for a couple of months. It turns out I was ignorant and when I went to look at the BCM surprise surprise there is another fuse box down there, I found the radio fuse was blown, But my seat still moves forward, could it be the circuit breaker? Or should I continue and disconnect the LDCM and the RDCM and see if that stops it from going forward.
Old Apr 4, 2010 | 05:21 PM
dgrant3830's Avatar
dgrant3830
Re-memorize the seat position/memory.
Old Apr 4, 2010 | 05:39 PM
ZAXVETTE's Avatar
ZAXVETTE
This corvette is a striped model. It didn't even come with memory options... I have it disconnected at the moment I push back on the adjuster and it will stop the motion of the chair going forward, but won't let it go back? curious.
Old Apr 5, 2010 | 01:07 AM
dgrant3830's Avatar
dgrant3830
Did you by chance put in a SCM for a car with memory?
Old Apr 5, 2010 | 09:53 PM
ZAXVETTE's Avatar
ZAXVETTE
I honestly don't know I will have to check...the numbers out
Old Apr 5, 2010 | 11:18 PM
byronhunter's Avatar
byronhunter
Without Memory does not have SCM!!!!!!!!!
Old Apr 5, 2010 | 11:20 PM
byronhunter
I bet the Switch Panel on the side of the seat has water in it.
What year is it, I'll get you a Schematic?
Old Apr 6, 2010 | 01:09 AM
dgrant3830's Avatar
dgrant3830
So what little black box under the seat did he replace? Got me stumped.
Old Apr 6, 2010 | 10:53 AM
byronhunter
Me too! There is a Relay Center under seat without Memory, but I don't know what it looks like.
Old Apr 7, 2010 | 08:07 PM
ZAXVETTE's Avatar
ZAXVETTE
I think that is the one I replaced, I made sure the numbers matched when I ordered the part. I don't know what SMC means then, I thought it was the black box with the three different plugs that hook into it. It also attaches to the seat using the metal seat wires to secure it to the bottom almost right in the center of the seat. I am going to look at it this weekend and try and figure it out again, I will take pictures and maybe a video to show what I mean. To clarify the seat moves forward to the point of heating the motor and draining the battery it does not stop.
Old Apr 7, 2010 | 08:08 PM
ZAXVETTE's Avatar
ZAXVETTE
It is a 99, I am trying to make sure I can fix it before I buy it.
To Problems with the Radio and Seat
Old Apr 7, 2010 | 10:08 PM
byronhunter
ZAXVETTE, unplug the connector from the Switch pannel, that will eliminate one possibility.
Old Apr 7, 2010 | 10:55 PM
ZAXVETTE's Avatar
ZAXVETTE
So if I unplug the side seat switches and it keeps moving I know it isn't the switch, If I unplug it and it stops it IS the switch....
I didn't even think of that
Old Apr 10, 2010 | 02:08 PM
ZAXVETTE's Avatar
ZAXVETTE
The seat DOES NOT MOVE forward with the seat switch plug pulled, I opened the switch up and took pictures.....I can't see too much wrong with it, of course I am no expert either...what do you guys think?
http://www.ls1tech.com/forums/genera...l#post13167390
