air pump removal quesiton
Old Apr 4, 2010 | 11:06 PM
Erics_02_z06's Avatar
Erics_02_z06
Default air pump removal quesiton
so I searched, but couldn't find an answer. I removed the air system, but left the pump in place. I just removed the hose going from the pump to the engine compartement. My question is....will the intake suck unfiltered air through the pump now?? I didn't think about that when I removed it a few weeks ago. Also, if I plug the air filter box, what is the best way to do that/
Old Apr 4, 2010 | 11:53 PM
banner1's Avatar
banner1
You can get a vacuum cap from Autozone in a pack of misc sizes. Remove the air tube from the air filter to the pump and cap it on that plastic elbow that sticks out of your air filter.
I would pull the whole pump out. If you are not going to use it, you might as well save the weight.
Old Apr 5, 2010 | 06:25 PM
Nick1's Avatar
Nick1
I want to do the removal also, but what is involved with the computer editing that must be done to eliminate codes?
There must be a list of applicable codes that need to be cut out??? Do you know shich ones?
Old Apr 7, 2010 | 03:34 PM
Erics_02_z06
Thanks for the tips, filter box all plugged up, and removed. Thanks!
Old Apr 7, 2010 | 03:57 PM
lucky131969's Avatar
lucky131969
Originally Posted by WKMCD
The only component I have is the belt driven pump so I can pass visual inspection.
Belt driven?
Old Apr 8, 2010 | 12:37 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Originally Posted by lucky131969
Belt driven?
That's what I was wondering.
I left mine because how much could it weigh vs. the labor removing it. I'm lazy.
Old Apr 8, 2010 | 03:16 AM
Rohan's Avatar
Rohan
I remember doing this same thing to an old L98 Camaro that I had. My question to the pros would be 1. What are the benefits? 2. Will I trip any codes doing this?
Old Apr 8, 2010 | 09:10 PM
PewtVette's Avatar
PewtVette
P0410 AIR System
P0412 AIR Solenoid relay control circuit
P0418 AIR Pump Relay Control Circuit
P1415 AIR System Bank 1
P1416 AIR System Bank 2
I'm just finishing up my heads/cam install. I'm hoping my tuner will take care of these codes for me.
Yeah I left mine in as well. It would be fairly easy to re-run all the hoses if I decide to put it back in.
Old Apr 9, 2010 | 12:29 AM
Camjamsdad's Avatar
Camjamsdad
St. Jude Donor '13
Originally Posted by PewtVette
P0410 AIR System
I was able to wipe those codes out with my Predator. Older revision. The new ones were made EPA friendly.
Old Apr 9, 2010 | 08:00 PM
Nick1's Avatar
Nick1
What about P 0492? That's the one I keep having trouble with? Thanks
Old Apr 9, 2010 | 08:38 PM
lucky131969
In your case, P0491 and P0492 replaced P1415 and P1416 starting in 2004.
To air pump removal quesiton
