Halo Weatherstrip Replacement
I found good instructions on replacing the targa weatherstrip but nothing on the halo.
Other than removing as much of the old weatherstrip and glue as possible are there any other tips or tricks to be aware of when doing this project?
https://www.corvetteforum.com/forums...procedure.html
https://www.corvetteforum.com/forums...n-learned.html
GM weatherstrips, particularly in the case of the halo, had pressure sensitive adhesive strategically applied as needed. To my knowledge, none of the aftermarket do. The halo and targa strips both slip fit in the channels. The targa strips have fasteners through metal inserts at each end, the halo has fasteners through metal inserts at the corners, and christmas tree fasteners at the ends. Push pins (4 required) are 20538173 or 15762170. Halo weatherstrip 10415918, halo weatherstrip screws (4 required for halo, 4 [I think] for targa) 11508231. For the locations originally adhered with PSA, I use 3M weatherstrip adhesive, 08008. It's pretty much a black rubber contact cement, so one wrong touch and you teach yourself new curse words. You also need a smidge of 3M Strip Calk, 08578 for use at the body seams under the ends of the halo, etc. I bought the box from Amazon, so if you want a strip or three, shoot me an address.
https://vettenuts.net/1997-04-c5-cor...-part-10329158
https://vettenuts.net/97-04-c5-corve...13370-10313371
https://melrosetops.com/products/199...strips-gaskets
