how to remove exhaust plate
Old Apr 6, 2010 | 03:47 PM
jimbo409's Avatar
jimbo409
Default how to remove exhaust plate
I have a exhaust plate and it is on a little crooked. I tried pulling it off but it won't come off. how do you remove this.Thanks Jimbo
Old Apr 6, 2010 | 06:04 PM
Bakersfield's Avatar
Bakersfield
The one I put on had double sided sticky tape on it. Just slip a putty knife behind it and gently pry it off.
Old Apr 6, 2010 | 06:09 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
Yep, it's probably on there with double sided tape. If you get it off, you may want to try using velcro on the re-install
Old Apr 6, 2010 | 08:13 PM
rws.1's Avatar
rws.1
a heavy monofilament fishing line or dental flosss
pulling back and forth in a sawing motion
that is how I took mine off.
I then used some new double sided trim tape to re adhere it.
Old Apr 6, 2010 | 08:48 PM
robert123's Avatar
robert123
You can try to pry it off carefully with a screwdriver or get a hacksaw blade behind it and try to cut it out. When you reattach it, I would not trust the double sided tape. Mine kept falling off with the tape. I used clear silicone caulk to secure it. This will keep it secure and make removal easy as well.
Old Apr 6, 2010 | 09:16 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
much easier just to use some good velcro. A lot less of a mess as well.
Old Apr 16, 2010 | 04:36 AM
Jesse Asis's Avatar
Jesse Asis
Simple... hot air gun (or hair dryer gun) floss string, heat up behind aiming the hot air at the two sided tape (need someone else to hold this in place... then run the dental floss string top and bottom pulling and cutting the melting two sided tape... it will fall off shortly.. good luck.
Old Apr 16, 2010 | 10:53 AM
Bills03Coupe's Avatar
Bills03Coupe
working from the bottom, gently push a wide blade putty knife up while moving it from side to side. It will slowly work it's way through the adhesive, and you'll be able to pull it off. I do not agree with the Velcro for re-attachment however, it would make it too easy for someone to remove. Use 3M double sided tape to re-attach.
Old Apr 16, 2010 | 12:03 PM
rboineau's Avatar
rboineau
The plate I removed had double-sided tape so adhesive they could have used it to couple railroad cars together. The putty-knife routine advised by the other forum members will work, but be careful to keep the knife pressed against the plate and not scar the car's tub or whatever you call that thing the plate is attached to. Good luck; you'll have fun. Remember any car job goes better with plenty of profanity, and if possible a blood sacrifice(skinned knuckles from a slipped putty knife will do nicely--the car gods have to be satisfied).
Old Apr 16, 2010 | 03:16 PM
4SFED Z's Avatar
4SFED Z
A blow torch. J/K! As others have said.....pry it up with a putty knife!
To how to remove exhaust plate
