A/C won't blow cold
Old Apr 9, 2010 | 11:33 AM
GilbertBrooks's Avatar
GilbertBrooks
8th Gear
Default A/C won't blow cold
A/C won't blow cold. Heat works fine. Install a new A/C compressor belt. When you turn the A/C on, you can hear the compressor click and the clutch engages and turns. Freon level is good. Any idea what could be the problem (short of installing a new compressor!)?
Old Apr 9, 2010 | 11:49 AM
lucky131969's Avatar
lucky131969
Codes?
How do you know the freon level is good?
Manual or auto a/c?
Old Apr 9, 2010 | 02:03 PM
GilbertBrooks
8th Gear
Auto A/C. I don't have a way to check for codes. I put the gauges on the ports and hooked up the freon tank and it wouldn't take anymore freon.
Last edited by GilbertBrooks; Apr 9, 2010 at 02:12 PM. Reason: Forgot to mention Auto A/C.
Old Apr 9, 2010 | 02:34 PM
lucky131969
http://www.c5forum.com/ayc/dtcdic.php
That doesn't tell me much. Since you had the gauges, did you take note of high/low side pressures, and compare those values contained in the service manual?
Old Apr 9, 2010 | 03:02 PM
GilbertBrooks
8th Gear
I did. The readings were in the specified range. I've also checked the fuses. On a related issue, the digital display on the A/C - Heat controls is dim to black. But I've read on this forum that it is usually a broken/cold solder issue. I assumed that it doesn't affect the operation since the heat, blower speed, and outlet directions are working.
Old Apr 9, 2010 | 03:05 PM
lucky131969
and the codes?
http://forums.corvetteforum.com/c5-t...splay-fix.html
Old Apr 9, 2010 | 03:13 PM
GilbertBrooks
8th Gear
I don't have a reader to check codes.
I plan on performing the soldering fix this weekend.
Old Apr 9, 2010 | 03:15 PM
GilbertBrooks
8th Gear
This is the 1st Chevrolet I've owned. All of my tools are geared towards Ford products. I currently own these vehicles;
2001 Mustang GT Convertible
1998 Ford Expedition
1999 Mercury Cougar V6
1996 Ford F150
1993 Ford E450
1966 Ford Mustang 289
1997 Harley-Davidson Fatboy
Old Apr 9, 2010 | 03:18 PM
lucky131969
1996 Ford F150
1993 Ford E450
Ok great.....so one more time.....what are the codes?
Old Apr 9, 2010 | 03:22 PM
GilbertBrooks
8th Gear
I'm lost. How can I see the codes?
Old Apr 9, 2010 | 03:27 PM
lucky131969
Ya know, I'm not trying to be difficult.....but when you ask for help, and someone takes the time to respond.......and you don't even read your own thread....it makes it difficult for those trying to assist you.
Read post #4 again.....I don't have the patience for cat and mouse..but there are many knowledgeable guys on this forum to help.
Good luck....
Old Apr 9, 2010 | 03:32 PM
GilbertBrooks
8th Gear
I apologize. I didn't see the link in that post. This forum layout isn't the easiest to read. I'll open the link and read it now. Thanks.
Old Apr 9, 2010 | 03:36 PM
GilbertBrooks
8th Gear
WOW! I didn't know that you could read the codes like that! I'm currently in my office and won't be able to check the codes until this evening. I'll download the relevant code sheet for 2000 model year and check against any codes that show up. Thanks again and I sincerely apologize for overlooking that link.
To A/C won't blow cold
