Window adjustment help
Old Apr 11, 2010 | 11:08 AM
SkyWarp's Avatar
SkyWarp
Default Window adjustment help
I have a 2003 Z06. I got the door panel of already because i need to adjust the drivers window. The reason im doning this is the window need to go a little further back. How do you adjust the window forward and back(not tip in) Need the window to go back so it sits on the weatherstrip better. I already loosened the 2 bolts on the window clamps and tried to tap the window back, but it did not work. Any help would be great tks
Rob
Old Apr 11, 2010 | 11:45 AM
Terry34's Avatar
Terry34
After making sure the clamp bolts are really loose try moving the window slightly at the clamps to make sure that the window is free from the clamps on both sides. Then you can slide the window backwards.
Old Apr 11, 2010 | 12:15 PM
Edmond's Avatar
Edmond
This is something I have to do as well on my '03 Z. The window doesn't sit back far enough on the passenger side and I'm getting wind noise.
How bad was it to remove the door panel?
To Window adjustment help
