Transmission Help
Old Apr 11, 2010 | 03:12 PM
rand819's Avatar
rand819
3rd Gear
Default Transmission Help
I have a 1999 Corvette hard top. The previous owner put a 2007 transmission in my 1999. now the wiring does not match up the transmission is fine but the wiring does not match up. Does anyone have any suggestions on what to do. thanks
Old Apr 11, 2010 | 04:12 PM
lucky131969's Avatar
lucky131969
What to do with what?
Old Apr 11, 2010 | 04:20 PM
rand819's Avatar
rand819
3rd Gear
My mechanic said that the 2007 transmissions electrical components don’t connect up correctly with the 1999 wiring. Is there a harness or wiring configuration that can be used to hook up the 07 tranny correctly.
Old Apr 11, 2010 | 04:40 PM
lucky131969
Like an adapter harness? I have no idea........
Old Apr 11, 2010 | 05:05 PM
dougbfresh's Avatar
dougbfresh
Auto? I don't believe it will work since your C5 computer won't know how to converse withl the C6 trans even if you get the wiring correct.
Old Apr 11, 2010 | 11:28 PM
rand819's Avatar
rand819
3rd Gear
thanks for the help. it is a manual trans. the trans matchs up with the car but the wiring is different and making my check engine light stay on. i was just trying to get some advice as to if anyone has had the same problem. its just that there are more wires on the trans then the old one. does anyone know how to wire a new c6 trans into a c5. thank you
To Transmission Help
