HELP.. rough running
Old Apr 12, 2010 | 03:47 PM
88sk's Avatar
88sk
Default HELP.. rough running
my 2k 6 spd. is runnin rough ,its got heads ,cam,exhaust & was was tuned by ECS a few years ago ,ran great up until last october ,ran a new tank of gas thru it & it runs rough & backfires ,no codes stored just a flashin check engine light ,took it to a close by pep boys (I know) he didnt know cause of no codes ,clears up a little above 2500 rpm any ideas?
Old Apr 12, 2010 | 04:03 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I'll be happy to check it for you if you like. Let me know if we can help.
It could be something as simple as a bad ignition wire.
Old Apr 12, 2010 | 04:18 PM
lucky131969's Avatar
lucky131969
You can pull your own codes:
http://www.c5forum.com/ayc/dtcdic.php
Inspect your plugs and wires.
Old Apr 12, 2010 | 05:05 PM
redrckt97's Avatar
redrckt97
could also be a broken valve spring - how many miles on the springs after the cam install??
Old Apr 12, 2010 | 05:30 PM
happa's Avatar
happa
I would check the plugs and wires first. That might be a good start. Good luck
Old Apr 13, 2010 | 08:32 PM
88sk's Avatar
88sk
I still have the stock wires ,I have 26 k on the motor ,had about 19k when I did the install
Old Apr 13, 2010 | 09:07 PM
lucky131969
And what is the result of inspecting the plugs and wires?
Old Apr 15, 2010 | 09:10 PM
88sk's Avatar
88sk
You know your stuff ,I changed the plugs & put the stock wires on & it runs damn strong ,hard to believe thats what it was ,the mechanic at pep boys was clueless,lesson learned ,thanx & I mean that.
Old Apr 15, 2010 | 10:40 PM
lucky131969
Huh...imagine that.....
Old Apr 16, 2010 | 12:57 PM
88sk's Avatar
88sk
Lol
To HELP.. rough running
