I'd be very concerned about forming a perfect flare to withstand the higher fuel pressure of today's cars. There must be a reason that none of the manufacturers use flared fittings anymore.
In the "ol' days" when fuel pressure was 4-8#, flared fittings were common...
You can also buy an adapter fitting and go from the quick disconnect to AN connector and disconnect at the AN connector.
I'm not thrilled with the disconnects, but with a cheapie autozone disconnect tool it's not that bad. It reminded me of some German made disconnects that held a big one inch water line. They were kind of the same style but about three inches in diameter. Now those were a pain in the *** to take off and remove.
I have the adapter and just feel better about a solid AN fitting over a hot manifold. I'm thinking if aftermarket rails and braided lines use them, they can't be that bad. I can put a solid line in it's place but I'd love to use the existing line if I can.
I'm confused at what you hope to accomplish. Unless you install a complete custom fuel system, you are going to have a quick disconnect somewhere...either at the fuel rail, or at the fire wall. Perhaps I'm missing something, but it doesn't make much sense....based on my understanding.
My question specifically is whether the existing fuel feed line, right above the drivers side manifold, has been flared (double-flared in my case) by anyone or can be confirmed that it really is some sort of metal and can be flare-able. I can and will use quick disconnects elsewhere but right where the feed ends (right above that exhaust manifold) is where I want to put a -6 tube and sleeve and flare it.
I've tried most variations of fuel systems out there and currently run an aftermarket in-tank and external in-line pump to help pressure when extra volume is required. I have hard lines running thru the drivers-side rocker panel, feed is -8 y'd to -6's into Aeromotive rails. Rails. Returns are y'd back to a referenced regulator and flow -6 back to the tank. Aside from simplifying things because the new setup isn't going to do ridiculous power, I am moving hard-lines from the rockers back to the tunnel. Since I've run flared fittings beyond 80 psi w/ no problems before, I see no reason to go with a disconnect when it makes sense for me to do otherwise.
I do agree that the stock system, for most, is good enough left alone
the lines are aluminum and can be flared. I developed a pin hole leak in a line once. Cut the hole out. flared each end and slipped a piece of rubber hose over the line. This was just to get me by until I could fix it properly.
You can buy a fitting that converts the quick disconnect to a -AN fitting. You might check into that. IMO, I think the GM quick disconnect fitting provides a better seal than a AN fitting and braided line.
As always, the devil is in the details. Makes sense now, since that is the last QD fitting in the engine compartment.
You've got to be kidding a QD holding more pressure then a double flare?
What do you think are on your brake lines?
GM went with QD for 2 reason's "COST" it's cheaper to make and it's quicker to assemble!
a flare fitting is going to be much more reliable the a QD. only problem is that once the flare joint is disassembled, the flare should not be reused. i remember a fuel seal tester my class designed in college that used a very thin aircraft fuel at around 350psi i beleive it was. nearly all the connections we used were flare fittings.
Thanks, this is what I needed to know.
I believe you on the GM connector being a better seal... at least when in tight quarters and when being put together in an assembly line. It is definitely more convenient and may end up being used (kept) if I can re-position/bend the line to get it further away from the exhaust heat, Btw, it'll be used as a return line so it'll be seeing very little pressure and a new steel line is being put in for the feed.
As long as the line is a size that can accept a flared fitting you should be fine flaring it. I don't even see why you need a double flare. I'm not sure the aluminium lines will take kindly to being double flared and besides it's is only around 60psi or so. Single flare it and crank the fitting on tight and you'll be fine.
Double flaring is usually done on soft tubing materials so the actual sealing flare does not become damaged (or splits at the seam) when tightening the tube nut/bushing.
The double flare is no better at sealing or rated for higher pressure than a single flare. Stainless tubing, for example does not need a double flare.
As for flaring, and pressure, I quite often flare steel tubing for use in hydraulic systems that sees in excess of 3000psi. The 60psi fuel system is not even close to the ballpark of "high pressure".
One last thing for the OP, please note most double flare tools are for a 45° SAE flare angle.
The (higher pressure rated) AN/JIC fittings are 37° taper. You MUST flare it @ 37°, or it WILL leak!
Thanks, I'm having a local shop do the flaring on the additional steel feed line as it's a pain in the butt when compared to aluminum Thank god the stock lines are aluminum...
