P0303
Old Apr 13, 2010 | 09:42 PM
Fujikura's Avatar
Fujikura
Default P0303
Ok, so I had a P0420 and a faulty Oil Pressure sender. I took it to a local mechanic I know, he replaced my 02 sensor and Oil Pressure sender. He also told me that I had a bad exhaust leak and needed to take it to a muffler shop to re-do the welds. Once I took the car home it was fine, but within an hour or so I noticed the car started to hesitate at around 60-70 MPH, I was concerned.
I figured it might have been due to my exhaust leak and my CEL popped back on generating the P0420 again. Re-enforcing my initial thoughts. It was later so I waited for another day to take it to the muffler shop. The next day my CEL began to flash, I had my code reader so I plugged it in and it had P0303 then P0420. I took it to a muffler shop and they welded the exhaust leaks and gave the exhaust a good look through and it was good.
Unfortunately the car still hesitates, no CEL, yet...I was wondering if perhaps the misfire/hesitation can be from the intake manifold not being re-installed correctly. Please help!
Old Apr 13, 2010 | 09:57 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Is your AC and heat working correctly?
Old Apr 13, 2010 | 11:24 PM
Fujikura's Avatar
Fujikura
No it's not the passanger side works, but the driver side if it's heater blows cold air and if it's ac blows hot air I didn't think that had any impact, though?
Old Apr 14, 2010 | 12:16 AM
lucky131969's Avatar
lucky131969
You have a miss on #3 cylinder. Since the intake manifold was just off, I'd inspect the injector wiring harness for the left bank, paying particular attention to the security of the connector for #3 injector. The P0420 is for cat efficiency on the left side...could be an exhaust leak, bad O2, or bad cat.
Old Apr 14, 2010 | 08:16 AM
Mark C5's Avatar
Mark C5
If the AC and heat worked before the intake was removed there is an excellent chance the vacuum hose at the back of the intake is off.
Old Apr 17, 2010 | 12:30 PM
Fujikura's Avatar
Fujikura
Well I took it down to A&A Corvette and they changed my cats out, but found my drive shaft was done for, so they fixxed that. changed my spark plugs and checked my wires and the car was fine, so when I took it to get smogged today the guy was warming my car up and about 2min in it started misfiring now it's shooting out the P0300 code I'm so frustrated it was fine at Andy's and now it's acting up again! The guy said that it looked like the intake had not been removed at all when he did the oil pressure switch that sits behind the intake.
Old Apr 17, 2010 | 02:27 PM
lucky131969
What were the condition of the plugs? Did number 3 look different? You had a P303 before. Did you inspect the wiring to #3 injector, connector, etc.
Who is "the guy"? How would one determine if the intake had been removed or not? The sign of a good mechanic, is to leave no signs that the car has ever been apart......yet all repairs are done.
Old Apr 17, 2010 | 08:36 PM
Fujikura's Avatar
Fujikura
I forget the tech's name at A&A Corvette and he said the spark plugs all looked ok, but a little white. Not sure what he meant, but he checked the connectors, then tested the car and it was fine but acted up again when I was about 1/2 way home. Has new plugs now.
Old Apr 17, 2010 | 08:41 PM
lucky131969
Yeah that sucks, as luck would have it, the car was on it's best behavior while at the shop... I guess you'll have to take it back to Andy, if you don't intend on doing anything yourself.
Old Apr 17, 2010 | 09:01 PM
Fujikura's Avatar
Fujikura
I was thinking of replacing the coil packs and wires myself that seems, easy just remove some bolts and wires, etc..? right?? Would uprading to MSD's help? Also would I need to replace those wires? (not sure what they're called) Also the injectors could be a cause, should I put injector cleaners in or replace/upgrade them as well?? When it comes to vacuum leaks I'm a bit at a loss for that...
Old Apr 17, 2010 | 09:06 PM
lucky131969
I would suggest troubleshooting over replacement(can get expensive in a big hurry). Do you still have a P0303 or just a P0300? Are you getting a flashing check engine light as well?
Factory parts are all you need where wires and coils are concerned....no need for MSD's. Injector is a possibility, or associated wiring.
12495519 – GMPP red spark plug wire set
Old Apr 17, 2010 | 09:08 PM
Fujikura's Avatar
Fujikura
I have gotten a flashing CEL before, not lately. P0303 isn't on now, it was when I gothome, but I reset it and the p0300 is now I havent driven it, really all day, been a bit slumped
Old Apr 17, 2010 | 09:18 PM
lucky131969
Ok, so my understanding is, when you checked codes upon returning from A&A, you had a P0303C...."C" meaning current, not H. If this is the case, then #3 cylinder is still the culprit. Since the plugs were just changed, you can do a few things to isolate the issue.....one at a time.
1) Swap the #3 plug wire with another cylinder, and see if the code changes. Personally, I'd just change out the wires, since you did the plugs.....that's just me.
2) If the above does not yield any result, you can swap the #3 injector to a different position (provided you are confident the wiring is all good).
3) If neither of the above yield any result, you can swap coil packs with another cylinder.
Old Apr 20, 2010 | 07:22 PM
Fujikura's Avatar
Fujikura
It looks like I have a bad intake manifold, trying to find one now, my code reader read a
P0303, but the actual code was a P0300, cylinder misfires in 3,5, and 7 the manifold is not sealing correctly due to a crack...
Old Apr 20, 2010 | 07:33 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
P0300 is the only misfire code that will ever display in the DIC. It is a catch-all code for any/all misfires detected, all that is needed for OBDII purposes.
The last digit (P0303) further identifies the specific cylinder that's misfiring, but that can only be read with external scan tools.
To P0303
