wind noise from pass. window
Old Mar 14, 2002 | 04:58 PM
rick g's Avatar
rick g
Default wind noise from pass. window
does anyone have wind noise in their 2001 conv. from the top of the pass. side window, and if so have you attempted to fix it or have it fixed? I just don't know if it is worth leaving my car at the dealer for this warrenty work. (how many test drives would it take to fix it!) :rolleyes:
Old Mar 14, 2002 | 08:40 PM
MySea6's Avatar
MySea6
Default Re: wind noise from pass. window (rick g)
Try the adjustment below. Might help and is very easy to do. Don't worry about the inverted torx, a small 6pt socket works fine.
From the manual:
Window Tip-In Adjustment - Door
Tools Required
#6 Inverted TORX® Socket
1. Position the window fully up.
2. Remove the large access plug from under the front of the door.
3. Loosen the window regulator front channel mounting nut.
4. Remove the reflector from the trim panel
5. Loosen the jack screw jam nut.
6. Adjust tip in with the jack screw.
* Turn the jack screw clockwise to tip the window outward.
* Turn the jack screw counterclockwise to tip the window inward.
* One turn of the screw equals approximately 1 N·m (0.04 in) change at the
top of the window.
7. Tighten the jack screw jam nut.
8. Lower the window.
9. Tighten the window regulator channel front mounting nut.
10. Raise the window and check the alignment.
11. Install the access plug under the front of the door.
12. Install the reflector in the door trim panel.
