oil pressure sensor
Old Apr 14, 2010 | 08:25 PM
ditoc5's Avatar
ditoc5
Navigator
Default oil pressure sensor
oil pressure sensor has been changed 3 times, works fine for about a week then guage pegs to 80. dealer thinks it might have something to do with the oil pump relief valve.
Old Apr 14, 2010 | 08:47 PM
byronhunter's Avatar
byronhunter
Does it read above zero with the Ign on, engine off?
Old Apr 14, 2010 | 09:03 PM
lucky131969's Avatar
lucky131969
Have you verified with a mechanical gauge?
Did you inspect the wiring yet? A bad ground to the OPS will cause this indication.
Old Apr 14, 2010 | 10:39 PM
dirty-c5's Avatar
dirty-c5
If they are not useing the brass one it will keep going bad. It also has to be torqued just right. I torqued mine to right at 15 ft lbs when I installed it a month or so ago and no problem. I also used a brass borge warner one from Oreilly auto part.
Old Apr 14, 2010 | 10:47 PM
lucky131969
Not true.
Old Apr 14, 2010 | 11:54 PM
dirty-c5's Avatar
dirty-c5
Well after using the aluminum one and it lasting a day 3 times in a row then swapping to the brass borge warner and its been in for a month or longer It definetly seems like a problem with the aluminum ones.
Old Apr 15, 2010 | 12:12 AM
byronhunter
I installed an aluminum one a few months ago, not a problem!
Old Apr 15, 2010 | 12:34 AM
dirty-c5's Avatar
dirty-c5
Maybe I just had bad luck with them. Each one failed after the first time of driveing the car and it was the same thing. The gauge would peg even with the engine not running.
To oil pressure sensor
