Cooling fan temp program?
Old Apr 14, 2010 | 10:38 PM
thetitan's Avatar
thetitan
Default Cooling fan temp program?
What kind of OBD II programmer is required to set the cooling fan on/off temps? Will a cheap OBD II scanner work?
Thanks, Titan
Old Apr 14, 2010 | 11:11 PM
lucky131969's Avatar
lucky131969
Thanks, Titan
No. You need a programmer.
Old Apr 15, 2010 | 12:08 AM
Quick Shot xMLx's Avatar
Quick Shot xMLx
This, I lowered my fan-on temps a bit with HPTuners.
Old Apr 15, 2010 | 10:03 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The easiest and most inexpensive way to change your fan set point is to buy a Vinci fan controller.. easy to revert back to stock settings in the winter...
Bill aka ET
Old Apr 15, 2010 | 10:10 AM
Evil-Twin's Avatar
Evil-Twin
The easiest and most inexpensive way to change your fan set point is to buy a Vinci fan controller.. easy to revert back to stock settings in the winter...around 150 dollars
The same exact unit
is
available from PEP Boys Auto stores for $39, and sold under the OEM
manufacturers name
"Hayden". It is usually found near the
aftermarket electric radiator fan kits, often
behind the parts
counter. You may have to look yourself, as some store employees
have no
idea what you are talking about. its packaged in a clear wraped card.
Bill aka ET
To Cooling fan temp program?
