Help adjusting headlight panels.....
Old Apr 15, 2010 | 04:09 PM
IRON MAIDEN's Avatar
IRON MAIDEN
Default Help adjusting headlight panels.....
Not sure what to call it. But when the lights are down, I want the same spacing all the way around the panels. Both side need to be tweeked a bit but i have no idea how to do it. Tried seaching with no luck.
Old Apr 15, 2010 | 06:59 PM
jellis's Avatar
jellis
turn the lights on so that they flip up. there are 2 Torx screws in the back which you can see when the hood is open, there are also 2 Torx screws on the side of the headlight, one on each side. you can loosen the screws to adjust the placement of the light covers.
Old Apr 15, 2010 | 08:12 PM
Nick1's Avatar
Nick1
I just had my right cover off the other day, and noticed that you can adjust any of the corners essentially up or down to get an even looking fit. However, I don't see how you can move side to side. Perhaps by moving the whole headlight assembly first a bit, then adjusting the lid to suite may work.
Old Apr 16, 2010 | 05:25 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
The black plastic piece that the cover screws unto provides for lateral adjustments... It's really a PITA as you have to replace the cover to see if it's right, then remove it again to make another small adjustment again ect. I have one off a little and played with it for about an hour before I felt like throwing the screw driver and retreated...
I'll go it again when I have more time and patience!
Old Apr 16, 2010 | 02:01 PM
corvettebob1's Avatar
corvettebob1
tstar is absolutely correct in his assessment, it's a total pain in the a$$ and will try a saint's patience!
Now here's a little trick I did and it worked for me, I loosened all the adjustment screws and just snug ed them up until I could put the cover back on and move it around.
It will move in all directions so be careful, when I got to where I thought it was good I removed the cover and tightened up all the screws.
Well it did take a couple of times but it sure beat the crap out of R&R the cover to make 1 adjustment at a time.
Of course then you will have to adjust the height of all 4 corners because they will be off after aligning it around the sides.
To Help adjusting headlight panels.....
