mail order tune
Old Apr 17, 2010 | 06:06 AM
luc719's Avatar
luc719
Default mail order tune
I see allot of people talking about mail order tunes, and was wondering what are they and how do they work
Old Apr 17, 2010 | 07:38 AM
Joey1121's Avatar
Joey1121
Here is a link to ECS. They have a short description on their mail order tune.
http://www.eastcoastsupercharging.co...ynotuning.html
Old Apr 17, 2010 | 08:12 AM
rws.1's Avatar
rws.1
tuners record and maintain copies of all the live dyno tunes they have done.
all though each car is unique, those with similar mods will benefit to similar degrees to the same tuning.
You tell them whatbolt on mods you have done ( 1 3/4" AR headers, Vararam, Borla exhaust, Shainer throttlebody etc) they look to see a similar tune they have done for that exhaust combination and load it onto your PCM.
while the dyno tune might get you another few percent improvement, the mail order tune gets you most of what is achievable with your set up for a fraction of the price.
The Vette engine is governed by tables stored in the PSM. They control the air fuel fixture, timing, etc. the tuner remaps those tables using values they have previously determined on a dyno tune that generates more HP under those set of conditions witht he bolt on you have.
You just send them your PCM and the $$$$
The PCM is located behind the splashguard at the rear of the passenger side front wheelwelll
For a few $$$ more some will send you the tunes via E-mail and through data logging optimize even further. that doesn't require the PCM to be sent in , but you do need access to a laptop and the cord to connect to the car.
Old Apr 17, 2010 | 08:17 AM
rws.1's Avatar
rws.1
I saw this post by a highly respected tuner just after I posted....
http://forums.corvetteforum.com/c5-t...chuck-cow.html
Old Apr 17, 2010 | 10:51 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Heres their mail order tune special
http://forums.corvetteforum.com/c5-s...nly-149-a.html
Old Apr 17, 2010 | 10:53 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
they work great with mild mods but if you have greatly changed the engines pumping ability them you will need more than just a mail ordere tune.
Old Apr 17, 2010 | 07:23 PM
81c3's Avatar
81c3
I had a mail order tune done and I thought everything was fine. When I got the car dyno tuned, I found out how far off the tune really was. If you can get a dyno tune done, skip the mail order tune. I got my dyno tune done for $275. Thats not much more than the mail order tune was when shipping is factored in.
To mail order tune
