turn signal
Old Apr 17, 2010 | 07:15 PM
mwlindy66's Avatar
mwlindy66
Cruising
Default turn signal
can any one help me turn signal and hazards randomly work. will work than stop working it is 2001. thankyou for any help
Old Apr 17, 2010 | 07:53 PM
rws.1's Avatar
rws.1
The hazard switch needs to be replaced... search for DIY...
There are two one requires pulling the whole dash, the other has you removing the radio and reaching in...
A formum member also sells a bypass kit...
Old Apr 17, 2010 | 07:57 PM
mwlindy66's Avatar
mwlindy66
Cruising
thankyou for your help i'll try that
Old Apr 17, 2010 | 08:36 PM
RSchleder's Avatar
RSchleder
Buy the aftermarket bi-pass flasher unit and be done with it. Takes about 15 minutes to install and your problem will be gone. The OEM flashers are prone to failure and are difficult to replace so IMO, they are not preferred when replacing. Try this link, good luck, Ron
http://www.corvette-enhancements.com/
Old Apr 17, 2010 | 10:37 PM
CrazyMagMan's Avatar
CrazyMagMan
St. Jude Donor '05
May have to give this a shot as my wife's '01 is having this problem also.....
To turn signal
