yank 3200 lock up problem, HELP!!!
Old Apr 19, 2010 | 03:38 PM
briansshop's Avatar
briansshop
Default yank 3200 lock up problem, HELP!!!
I have a 98 c5 that had a stock converter and gear. Over the winter I put a yank 3200 converter in with a 342 gear. Now when you first get to overdrive the converter will lock in, when you speed up it unlocks and than never re locks. Yank said to make sure it is set at 48mph lock up speed in over drive, and it is. My tuner can lock it with his lab top wile driving, so we don't think it is the converter. I have checked and cleaned all the grounds and trans connections. ANY ideas?
Old Apr 19, 2010 | 06:11 PM
2079's Avatar
2079
I removed lockup in 3rd gear whit your set up...no more lock unlock...ect.....it worked for me.
Old Apr 19, 2010 | 08:37 PM
OhioC5's Avatar
OhioC5
I had the same set up in my 97, will send you my tune if you like. I use HP tuners by the way.
Old Apr 20, 2010 | 08:39 AM
briansshop's Avatar
briansshop
yea, that would be great, how does removing lock up in 3rd make 4th lock up work? I don't understand?
Old Apr 20, 2010 | 05:30 PM
2079's Avatar
2079
What I'm saying is that I had a similar issue and by deleting lockup in 3rd gear it rectified my problem... I'm only seggesting that you try this only an other option/ possibility ??. Hope you sort it out Good luck.
Old Apr 20, 2010 | 05:59 PM
briansshop's Avatar
briansshop
thanks for the info, I didn't know that my tuner had already done this also. He had the same thought, also another symptom of this problem is that when I get on it real hard the car will climb to 6500 rpm or so and stall out and quit running for a second and my OBD 2 port looses power for a second. After this happens the converter works normal for a while.
Old Apr 21, 2010 | 08:42 AM
briansshop's Avatar
briansshop
still looking for answers.
Old Apr 21, 2010 | 12:35 PM
feeder82's Avatar
feeder82
make sure your tuner has the right rear gear ratio (3.42) in the tune, it will throw off the lock up if its not right.
Old Apr 21, 2010 | 02:50 PM
briansshop's Avatar
briansshop
yup he has it in the tune, Thanks
Old Apr 22, 2010 | 08:54 AM
briansshop's Avatar
briansshop
still looking
Old Apr 25, 2010 | 06:09 PM
briansshop's Avatar
briansshop
no body?
Old Apr 25, 2010 | 06:14 PM
2079's Avatar
2079
Originally Posted by briansshop
no body?
Come someone must have something for this guy.....There are many tuners out there, show us your stuff and expertise.
Old Apr 25, 2010 | 06:41 PM
TurboBerserker's Avatar
TurboBerserker
Er... This is a bit scary. You need to track down this electrical gremlin before trying to debug the tune.
To yank 3200 lock up problem, HELP!!!
