Bigger Brakes
Old Apr 19, 2010 | 04:53 PM
wvufan1965's Avatar
wvufan1965
Default Bigger Brakes
Will the Z51 C6 brake upgrade really show results over the slotted C5 rotors and carbotech high performance pads?
I soon will be almost 500 to the wheels and do drive the car hard. I currently have Hawks hps and napa rotors with steel lines.
Looking for experienced input please.
thank you
Old Apr 19, 2010 | 11:43 PM
MTPZ06's Avatar
MTPZ06
thank you
Based on what I've read, I'm going to say no...but since I'm not speaking from personal experience, I'll move along.
Old Apr 20, 2010 | 01:38 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
If you want a true upgrade to your stopping power then the Baer Extreme 6 piston kit is a great way to go. Your choice of the Mono block or 2 piece caliper.
http://estore.websitepros.com/2120533/Detail.bok?no=105
http://estore.websitepros.com/2120533/Detail.bok?no=104
http://forums.corvetteforum.com/c5-t...tems-sale.html
enter BAER for 5% off annversary Sale
Old Apr 20, 2010 | 06:33 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
thank you
I've been autocrossing and taking my car to HPDEs regularly for the past three years with a setup that is close to yours (HAWK HP+ pads) and have never found myself wanting for more braking power. Go to the autocross and road racing section, there are many members running the stock brakes with upgraded pads. The stock braking system on these cars is very good.
Unless you add a bunch more weight to the car or plan on doing multiple consecutive stops from very high speeds (>130 mph) I see no need for increased braking power just because your RWHP has increased. This is just one individuals opinion, I'm sure there will be others that will recommend spending thousands of dollars on hardware you do not need.
Old Apr 20, 2010 | 12:29 PM
BoostRetard's Avatar
BoostRetard
I recently switched to C6 Z51 brakes. I did feel a pretty good increase in performance, but I also switch from stock/generic? pads to Hawk HPS pads and from Khumo MX runflats to Nitto NT-05's. I assume the change is more due to the pad and tires rather than the increased rotor size. I am glad I switched, but I also wanted to change wheels/tires. I was also dealing with a squeal in the rear brakes that was driving me nuts. I am happy with everything, but I can say I would recommend the change unless you were also wanting to do the wheels and rotors anyways.
Old Apr 20, 2010 | 01:28 PM
1999_TRC's Avatar
1999_TRC
Will these brakes work with stock C5 rims?
Old Apr 20, 2010 | 01:37 PM
99blancoss's Avatar
099blancoss
Former Vendor
18" and bigger wheels, there is a template that you should download and use to check fitments. Shown in the picture is an 18" Corvette Garage Z07 wheel (it is advertised as)
To Bigger Brakes
