Hissing sound inside dash
Old Apr 15, 2011 | 06:20 PM
C5XTASY's Avatar
C5XTASY
Interesting. I've got a hiss if the unit is off, or if air is directed just to the floor or to the floor and the dash outlets. If directed to just the dash outlets, there is no hiss. Don't know where to look. I know the dealer is going to want an arm and a leg to find it.
Ed
Old Apr 15, 2011 | 10:24 PM
vette.mix's Avatar
vette.mix
Old Apr 16, 2011 | 07:13 PM
yaknow's Avatar
yaknow
Originally Posted by vette.mix
Old Apr 16, 2011 | 09:40 PM
dmarkshark's Avatar
dmarkshark
Excuse my ingnorance, but what is the meaning of the popcorn? I can guess, but?
Old Apr 17, 2011 | 11:00 PM
3musky3's Avatar
3musky3
Default hissing in dash
i have same vacuum leak noise when unit is off or floor air is on no noise in defrost (2000 frc auto climate control) have not looked up
exact vacuum line but from other gms i have worked on 1 can assume
floor actuator diaghfram or line to it since no noise when defrost is
selected i have also seen round vacuum connector at control panel
not properly seated or broke/pulled out line on it if you tell me year
and witch hvac i will look up on service info for you
Old Apr 17, 2011 | 11:56 PM
00Corvette's Avatar
00Corvette
Originally Posted by dmarkshark
Just an idea, but why not start with the electronic vacuum selinoid under the passanger side and work with each line to see if you can isolate it, as mentioned above. I can get you the infor on the colored lines so you can see what each goes to, but not until later tonight if you need that infor.
Old Apr 18, 2011 | 10:12 AM
tesfrank's Avatar
tesfrank
Exact same issue here... Noise goes away when I turn the vent on and redirect in front of me. But will return whenever I change the vent direction...
Old Apr 28, 2011 | 11:26 AM
Scoobi_FreeBSD's Avatar
Scoobi_FreeBSD
Just hover over the smiley in the smiley list when composing a message for a description of the smiley.
I just replaced a couple vacuum lines on my '02 coupe, I'm getting the hiss only when (electronic) A/C is on and recirc is activated. The HVAC vacuum source line on my vehicle is a thin purple line which is accessible from the passenger side floorboard.
The purple line apparently goes into the HVAC system and is split to various control doors that route conditioned air through the cabin. I haven't gone past the purple vacuum line. My hissing sound seems to be coming from this area, but I haven't reopened the passenger side floorboard yet to explore.
You may start with the purple line in your search and go towards the HVAC, or follow the black vacuum source line (which goes to a vacuum reservoir canister behind the right front fender - this is where I had to replace the vacuum lines in my case).
Hoping this helps,
Anthony
Old Apr 28, 2011 | 11:37 AM
Scoobi_FreeBSD
Here's a link with good HVAC repair info regarding the vacuum lines:
http://forums.corvetteforum.com/c5-t...nge-vents.html
Anthony
Old Jun 28, 2011 | 08:58 PM
Stephen_a_'s Avatar
Stephen_a_
Having a similar issue with my car as well. I've narrowed it down to the HVAC for sure since the hissing will change depending on if my HVAC system is on or off. The hissing I'm getting seems to happen when the HVAC is off though. When it's on it seems to disappear.
