Bad Slave Cylinder....?
Old Apr 20, 2010 | 09:09 AM
nightman06's Avatar
nightman06
Default Bad Slave Cylinder....?
Heres the problem, hopefully someone can provide me with some incite or experience.
Im driving on a slipping clutch for about three more days while I wait for my replacement in the mail. But my quesiton is whether or not the culprit to the slipping clutch couldve been a bad slave cylinder. I had a SPEC Stage 2+ installed w/slave cylinder and the thing was solid, after about 6 months of driving (no track) it started to already show signs of slipping. The thing is if I held down the clutch and really pushed on it I could feel the clutch pedal come back into my foot slightly and the slipping would go away. Almost felt, feels, like the slave isnt releasing the teeth fully back into the plate. If I attempt to engine brake I can feel the clutch slowly engage the plate after the pedal is fully released. I have no problem disengaging the clutch at all. In fact it takes minimal pedal input. I do not have a shim installed. Clutch fluid level has never dropped. No apparent leaking of any kind.
At the point the clutch is toast, I understand this, Im just trying to educate myself as to how it happened.
Thanks guys
Old Apr 20, 2010 | 10:23 PM
Carcass's Avatar
Carcass
I'm not an expert,but it sounds like the slave is "hanging up" and not coming back all the way.
Mine did something similar for about 3 weeks before it started puking fluid onto the garage floor.
Here's a link to some pictures of what I found inside the slave:
http://forums.corvetteforum.com/c5-t...-with-pix.html
This may not be what's going on with yours,but hopefully you're installing a new slave while you're in there-because if the clutch itself didn't cause the problem,then something in the hydraulics did...
Old Apr 21, 2010 | 06:45 AM
spoiled_boy's Avatar
spoiled_boy
1st Gear
Default Like Jog.
is it joggy? aha ... all about autos
Old Apr 21, 2010 | 09:53 AM
nightman06's Avatar
nightman06
I wouldnt be surprised with my luck that I pull everything out and that's exactly what I see. The slave definitely feels like "hanging up" just didn't realize there was anything within the unit that could cause this restriction.
To Bad Slave Cylinder....?
