Service ABS, Service Traction Control, Service Active Handling
Old 01-12-2014, 09:04 PM
  #601
mickfree
mickfree's Avatar
im a newbie can you send me the info too mick_e_smith@hotmail.com
Old 01-12-2014, 10:44 PM
  #602
alleyezonmyZ06
alleyezonmyZ06's Avatar
Can you please send me the info too? thanks!! andre_sarkissian@yahoo.com
Old 01-12-2014, 11:50 PM
  #603
Texan8205
Texan8205's Avatar
I got my C5 in August and get the service active handling error each time I drive. Please sent a copy of your instructions to Chas.Laine at gmail.com Thanks!
Old 01-13-2014, 11:30 AM
  #604
Tricky's Zo6
Tricky's Zo6's Avatar
I went on absfixer.com and followed the instructions. Had them repair it, and all is good so far. Easy to do, just cost you a little skin and blood, oh, and some coin.
Old 01-16-2014, 04:16 PM
  #605
Taglek
Taglek's Avatar
I have the same error messages can you send me your instructions?
Kevint@meissnerjacquet.com
Sent from my iPhone using IB AutoGroup
Old 01-16-2014, 09:40 PM
  #606
phoenix1017
phoenix1017's Avatar
Default Me too
Originally Posted by robert162
would appreciate you sending it to me as well at
rthompson10@hvc.rr.com
you guys are the best
Can I get a copy at phoenix1017@msn.com. Thanks!
Old 01-17-2014, 11:59 AM
  #607
DWC4
DWC4's Avatar
I'd be very grateful to receive your excellent tutorial as well - just bought an '03 and I"m getting all those messages occasionally. I'm going to do the ground wire maintenance that's been suggested. Also looking for a good iphone code reading app, any suggestions? THANK YOU tdw13418@comcast.net - Doug
Old 01-17-2014, 03:40 PM
  #608
Tingan
Tingan's Avatar
Hi! I never got your email Could you mail me again? niclastingstrom@hotmail.com
Thanks in advance///
Old 01-17-2014, 04:09 PM
  #609
cor28vettes
cor28vettes's Avatar
Received 1,105 Likes on 856 Posts
Want to get it while I can
vettes22@juno.com
many thnx
Old 01-17-2014, 05:45 PM
  #610
Taglek
Taglek's Avatar
Originally Posted by 8VETTE7
I sent the tutorial to your email.
However, you need to pull your codes to see if it is something other than the EBCM itself. Many different codes that are repairable can set the AH/TC lights on the dash and generate the Service........ messages. For 97 - 2000 C5's if the codes are because of the actual EBCM itself, there is no fix short of a replacement EBCM if you can find one. New ones don't exist and used ones are very scarce because of no new being available.
Here's how to pull your codes:
http://www.c5forum.com/ayc/dtcdic.php
OR
OK, I pulled my codes and got the following:
28-TCS C1217 H
28-TCS C1221 H
28-TCS C1222 H
28-TCS C1243 H
60-IPC B1527 H
99-HVAC B0367 H
AO-LDCM B2284 H
AO-LDCM U1255 H
AO-LDCM U1064 H
A1-RDCM B2283 H
A1-RDCM B2285 H
A1-RDCM U1255 H
A1-RDCM U1064 H
A1-RDCM U1016 H
A1-RDCM U1096 H
A6-SCM U1160 H
A6-SCM U1064 H
BO-RFA U1096 H
BO-RFA U1064 H
BO-RFA U1016 H
Should I reset and see if they reappear??
Old 01-20-2014, 08:35 PM
  #611
mickfree
mickfree's Avatar
Default Service Traction System/ Service Vehicle Soon/Active handling is warming up
OK im a little confuse as to what MY PROBLEM MAY BE. Service Traction System/Service Vehicle Soon message is constantly displaying. I ran the code and Im get C1283 H. Now it's my understand the steering is off, possibly before the steering is off center. However, im reading post that say if the your getting this message it's more than likely the EBTCM. So i don't know whether to send my module to absfixer or not. What I do know my abs system is not working and i constantly getting the service traction message.
Thanks in advance, yes I'm rookie!
Old 01-22-2014, 05:29 PM
  #612
Robert Byrd
Robert Byrd's Avatar
Can I get a copy at byrd331@comcast.net. Thanks.
Old 01-22-2014, 07:42 PM
  #613
choyt
Support Corvetteforum!
choyt's Avatar
Can I have one sent to choyt1@hvc.rr.com thanks in advance.
Old 01-25-2014, 03:21 PM
  #614
firemark2643
firemark2643's Avatar
May I please get a copy:
firemark2643@yahoo.com
Thanks!
Old 01-31-2014, 12:17 PM
  #615
myjoedee
myjoedee's Avatar
Done.
Hi,
I would also like a copy.
joedee@wisfi.com
Thank you!
Old 01-31-2014, 02:52 PM
  #616
myjoedee
myjoedee's Avatar
Done.
Did not get it? E-mail address is correct.
Joe
Old 01-31-2014, 03:40 PM
  #617
myjoedee
myjoedee's Avatar
Check your SPAM folder. It is a PDF file and many Emails don't like PDF's.
I copied your email address and pasted it as the destination. No indications back to my email of inability to deliver.
Got it. Thank you!
To Service ABS, Service Traction Control, Service Active Handling
Old 02-02-2014, 03:23 PM
  #618
Jackman
Jackman's Avatar
Default EBCM Problem
I have had this problem for a long time now. Right now the only code that pulls up is C1214 H&C. Also my warning lights have been coming on every time I drive the car. So this weekend I finally followed the 'sticky' 65 and I did everything. I checked all the grounds I could find, I checked the fuses and finally I removed the EBCM. That was not as easy as some make it sound, but I did it. I checked all the solder joints and they all looked good. Nothing even questionable on the joints, not like when I did my 241's. So I put it all together again and re-installed the unit. I started the car and the warning lights came on again. Made me want to curse, but it's Sunday.
Does that mean I need a new relay???
Old 02-02-2014, 04:03 PM
  #619
1motime
1motime's Avatar
May I please have a copy with pictures also? These lights are killing me.
Garrettcedric@att.net
Old 02-02-2014, 04:59 PM
  #620
Jackman
Jackman's Avatar
If your talking about the ABS problem just go to "Sticky" 65. It's all there and you can pull up instructions with pictures.
Quick Reply: Service ABS, Service Traction Control, Service Active Handling
