First of all I dont have a Level 3.5. Its a Level 3. Secondly, its not about the clutch pedal pressure. If you intend to use the Level 3 on the street and not dump the clutch at 2500-3000 rpm on a regular basis, it makes a terrible, embarrassing squelching noise due to pressure plate/flywheel glaze.
Steve at Monster sent me a video of a GTO making the exact same sound I described to him. He knew what the sound was when he sent the video. That tells me its a fairly regular occurrence and also why there is a Level 3.5 Its probably better suited for street driving.
ECS sold me the clutch and the sales guy said its just like the stock clutch. Its nothing like the stock clutch. Theres more to consider than the feel or pressure of the pedal when comparing clutches.
Like I posted earlier in this thread...this is EXACTLY the problem I have with the stage 3. And I got the exact same response from Steve at Monster. To me this proves its a common occurance. So again...if someone is looking for a streetable clutch, the Monster Stage 3 is not it, not for normal street driving anyway. If you get it you are clearly taking your chances - it is quite likely the clutch will glaze, chatter, make noise and generally stink. Buyer beware.
I built clutches for 30 years. You CANNOT have a race clutch with metal pucks act like street car clutch. It ain't happening. If you have a high HP car with a race clutch in it, don't drive it on the steet. Race clutches are built to hold, not to slip. They have a short life. Forget the noise. They are going to make noise! The guys that race professionally change their clutches weekly, and you expect it to last 1000's of miles of street driving. You can't have it both ways. A street clutch will be nice and soft, smooth and quite so your grandma can drive it. A high performance clutch will be rough and make noise. It's not built to last in street applications, so don't expect it to. So race your race car and drive your street car.
Not to add fuel to the fire but what about multi-disc clutches that are full-faced?
I think RPS makes a twin organic good for 700 RWHP. The puck style clutches do engage harshly, compared to the full face disc ones, at least the ones that I have tried.
I was just saying you can still get a streetable clutch that holds a lot of power in a twin. Although I'm sure some will debate that too.
The twin clutches add surface area to the assembly which is equivalent to going to a larger diameter. These in theory will do the job. The potential problem with them is more working parts. The centerplate must float between the 2 disks for a good release. Since the release gap for most clutches is about .050, this would have to be divided between 4 surfaces instead of the normal two. Several mfg's are also reducing the OD of the assembly when going to a dual. This negates most of the advantage of using a dual. The best bet is to use as large an OD as possible and stay with the organic friction surface. We have experimented with 1 organic disk and 1 metallic disk with some success. A good clutch shop can 'play' with types of frictions to come up with some custom applications.
ref - wouldn't you want the twin/triple to be a smaller diameter for less inertia? I mean as you mentioned if you stay at the same OD you effectively double your surface area so to try and compensate for the higher inertia you reduce the diameter but you still end up with a good amount of surface area over any other single disk?
FWIW: I just took a dual disk clutch out of my car after I got really tired of the rattle that is inherent with all multiple disk clutches. It was smooth and never chattered of grabbed. I seriously considered a Monster 3.5 until I found out they stopped making them. Sellers tried to convince me that the Monster 3 would engage smoothly without chatter and grab. That would make the Monster a truly MAGIC clutch. Every puck style clutch I've ever seen is grabby and chatters. It's the nature of the beast regardless of friction material. Now reports are coming in confirming my experience.
I ended up with a Spec 3+ which is just now finishing breaking in. I get stuck in rush hour traffic and need a smooth clutch. So far I'm very happy with the Spec 3+. I made a horrific "growling" noise as it was breaking in but that's gone now.
That's usually correct. But, the the Vettes have so much bottom end, that the gain in less inertia hardly noticeable. Most of the mfgs are making a twin out of 9" clutch disks and an import pressure plate (Mazda I think). An increase in sq. in. surface area, but the mean radius dimension is quite smaller, which defines the torque capacity. They machine the fulcrum on the main plate to increase the clamping pressure, but that reduces the plate travel - making it harder to release. High RPM engines with little low end torque, like IRL or F1, as well as NASCAR benefit greatly from less inertia and use 7.25" or smaller clutches with 3,4,5 disks. But remember these guys only expect a few hundred miles out of a clutch and they don't use it to shift. So all the clutch does is clamp. Total wear allowed is usually only about .040". So slip a few times in it's life and it's toast.
I run an old small block RP autocross car (C3) with 440 ft. lbs of torque and use a 10.5" single plate with a 6 pad button clutch (3 Fibertuff & 3 Velvetouch Metallic on each side). It launches hard with 13" Hoosiers and has never slipped in 3 years.
I ran a RAM Dual Street. It's rated for 900RWT. It's a great clutch but the dual disk rattle was out of character with my car..
That's one thing I was worried about before I ordered my McLeod RST twin (still waiting for it to be delivered). I didn't think that all twins rattled though.
They all do to some degree. Some people are more sensitive to it than others. The C5 drive train is not quiet to begin with. I just didn't want to add one more sound.
Squeaky monster level 3 here. Its very annoying on the street. But it does not slip when launching, it can take abuse. The only way it doesn't make the squeak is if I just let the clutch out slowly from idle with no gas. The pedal is way stiffer than stock. At the end of the day I'm not worried about the clutch not getting me home.
Thanks for posting up in this thread, your technical expertise in clutch design and the inherent problems with the different designs is very helpful in choosing a clutch.
