powerWindow problem!
Old Apr 22, 2010 | 04:22 PM
Myky1's Avatar
Myky1
Default powerWindow problem!
My driver`s side window is making bad "screaming" (skreeGG, pox, pux pox or something like that) sound when I open it. Sometimes it open`s only half way and stop`s! We can`t find the reason. Any idea?
Old Apr 23, 2010 | 06:43 AM
Myky1's Avatar
Myky1
No help?
Old Apr 23, 2010 | 12:52 PM
wclark@nj.com's Avatar
wclark@nj.com
Most common problems are the cable fraying or the motor/gear/clutch failing. You have to take off the door panel to check the cable. The motor has to be removed to check. Instructions can be found on the forum.
New/used replacements can be found on EBay. With choices being new OEM, rebuilt and new non-OEM.
A few months ago I purchased a new non-OEM from a place in Bristol, PA (EBay) and it's been working fine.
Old Apr 24, 2010 | 04:23 PM
Myky1's Avatar
Myky1
Sure everything have been checket and cable was ok, all was ok. Problem is still there and stays..
To powerWindow problem!
