right rear tail light problem
Old Apr 22, 2010 | 08:52 PM
daleweible's Avatar
daleweible
Default right rear tail light problem
thank god not my problem, but I have a friend without a computer [to belong to c.f.]. 2000 convert. right rear brake light and hazard right rear dont work. right rear turn siginal no problem. cleaned 4 ground boxs so far, changed brake light switch, cleaned all rear tail light assemblys. no r/r brake or 4 way hazard r/rear. changed all rear bulbs, anyone with similar problem & fix? we are sure it is a ground problem some where. going to put it in the air and clean the remaining grounds. and yes he was a GM engineer
Old Apr 22, 2010 | 09:01 PM
lucky131969's Avatar
lucky131969
If the left brake light works normally, then the stop lamp switch, and the hazard switch is not the problem. The contact in the MFS is a possibility, as the contacts are different from left to right. So you are either not getting 12 volts, or ground. Have you checked the connector with a meter?
Should have 12 volts at pin A(dark green wire), and ground at pin G (black wire).
