Can you explain TC Question
Old Mar 15, 2002 | 02:04 PM
Jerryk's Avatar
Jerryk
Default Can you explain TC Question
Can anyone tell me....if you have a TC with a stall speed of say 3000 rpm. than can you tell me when your in top gear doing 65 mph and only doing 2500 rpm you have not reached the stall speed of the TC. can someone tell me how this works. i can understand when going through the gears you reach the stall speed, what about the open road, thanks for any input :crazy:
Old Mar 15, 2002 | 02:11 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Default Re: Can you explain TC Question (Jerryk)
The torque converter clutch (TCC) is commanded to lockup when appropriate below stall speeds.
Old Mar 15, 2002 | 03:28 PM
Jerryk's Avatar
Jerryk
Default Re: Can you explain TC Question (ToplessTexan)
just what tells the TC to lock up is this a mech thing or a design thing and if you step on the gas does it unlock and lock back up at stall speed , is the stall speed the lock up speed under normal driving, can it lock up higher than stall speed.. :crazy:
To Can you explain TC Question
