one headlight will not come up.......sometimes
Old Apr 23, 2010 | 03:50 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default one headlight will not come up.......sometimes
i have a friend with a 03 coupe with 9000 miles on it and the drivers side headlight will not come up sometimes. if i tap on the motor it will work fine for a week or so .anyone have any ideas? thanks
Old Apr 23, 2010 | 06:26 PM
BHRZ06's Avatar
BHRZ06
Check the connectors for corrosion pull the connectors and check the pins. If all looks well you could proceed as following
Option 1 remove the motor and clean the brushes and the shaft they ride on. Pretty easy just did this to my z06
Option 2 buy a replacement motor
,......any grinding noises or does it just not operate?
Old Apr 24, 2010 | 07:15 AM
Oldvetter's Avatar
Oldvetter
Usually a stripped plastic headlight gear is the cause. It will get worse, and cause a "machine gun" sound later.
There are 2 vendors for metal gears, they cost about $50 (or 2 for $80), do a search. Takes a while to install, but MUCH cheaper than replacing motor.
Try:
http://forums.corvetteforum.com/c5-t...with-pics.html
Post #2 and #29
Old Apr 24, 2010 | 03:35 PM
hdff's Avatar
hdff
Try:
Post #2 and #29
funny you mention the gear, the mail man dropped a bfranker gear off yesterday for my z. now i got to figure out how it goes in.......as for as my friends coupe there is no sounds, just a small tap on the motor is all that is needed...
Old Apr 25, 2010 | 07:44 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
My first step would be to shoot the connectors with electrical contact cleaner generously.......luck may be with you
To one headlight will not come up.......sometimes
