Help my DIC say "traction sys active"
Old Apr 25, 2010 | 08:54 AM
bs180785's Avatar
bs180785
3rd Gear
Default Help my DIC say "traction sys active"
Hi, can someone help me? my DIC say "traction sys active" when I drive down the road and then I lost the throtle. I have to turn the traction sys off get the throtle again.Can it have somthing to do with the tires? I have put new tires on with a difrent sise (285/30-18)??
Old Apr 25, 2010 | 10:01 AM
dougbfresh's Avatar
dougbfresh
If they are the same diameter YES, it's your tires.
Old Apr 25, 2010 | 10:07 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
A 285/30/18 is way too short for a rear tire.
If you are running that size all around, switching to a 285/35/18 size on the rear should fix it.
Originally Posted by 8VETTE7
If the front are not at least 1/2 inch taller than the rear you will certainly get the symptoms you have!!!!!!!!!
Wrong.
The rears must be taller than the fronts to avoid this issue.
Old Apr 25, 2010 | 10:27 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Probably your tire sizes as noted already. Pull your codes and see if anything is there. FYI, with software, you can change the tire sizes in the computer.
Old Apr 25, 2010 | 10:55 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Only for speedometer correction.
The TC system cannot be "tuned" for incorrect tire sizing.
Old Apr 26, 2010 | 03:12 PM
bs180785's Avatar
bs180785
3rd Gear
Default Thanks
Thanks for some good advices. my front tires are 255/40-17.
Old Apr 26, 2010 | 03:22 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Yeah, your current rear tires a bit shorter in height than that size front, this is the problem.
Switching to a 285/35/18 or 295/35/18 on the rear will solve it.
Old Apr 26, 2010 | 03:26 PM
bs180785's Avatar
bs180785
3rd Gear
Thanks I will try that.
To Help my DIC say "traction sys active"
