Clutch Adjustment
Old Mar 15, 2002 | 06:03 PM
Red63's Avatar
Red63
7th Gear
Default Clutch Adjustment
Hi everyone,
I have a question is there an adjustment on the clutch for a
C-5? If so how is it done..
:chevy
Old Mar 15, 2002 | 09:31 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Default Re: Clutch Adjustment (Red63)
The hydro clutch is self adjusting.
Tom
Old Mar 15, 2002 | 09:44 PM
C5 YA's Avatar
C5 YA
If you want to adjust the clutch, you need to buy an adj master cylinder. Cartek makes one. It has a quick disconnect to the slave cylinder, so it can be installed without removing the clutch.
Old Mar 18, 2002 | 03:28 PM
Red63's Avatar
Red63
7th Gear
Default Re: Clutch Adjustment (C5 YA)
Thanks guys,
I kind of thought that the clutch was self adjusting.
Thanks again :chevy
Old Mar 18, 2002 | 07:49 PM
Ray'98's Avatar
Ray'98
You can manually adjust the takeup point of the clutch. There are nylon adjusters (self adjusters) on the pressure plate. I guess there's about 5 or 6 of them that when moved in or out from the center move the point where the clutch engages/disengages in relation to the floor. It's like adjusting drum brakes, you can turn the star manually or let the self adjustment work its magic. This is not for the faint of heart but is possible.
To Clutch Adjustment
