Interesting fuel filter change discovery
Old Apr 29, 2010 | 08:36 AM
Alex99's Avatar
Alex99
Default Interesting fuel filter change discovery
Hi all,
yesterday I replaced my fuel filter on my 100k mile 2000 Coupe because I felt it was time.
The change went ok and afterwards I opened up the old one to see how dirty it was.
WOW! I was surprised how caked up the whole filter element was with a 1mm layer of sludge. The inside facing surface of the filter was clean though. Blowing through was definitely harder than through the new one.
I cut out a piece of the filter paper and let it dry and the dirty layer was flaking off in pieces. It definetely was hurting flow and my fuel pump will probably appreciate the new filters lower resistance. I will look out for improvements in engine operation.
After seeing that, I can only recommend changeing the filter. Next time I will change it much sooner (50k miles max.)
Old Apr 29, 2010 | 09:00 AM
lucky131969's Avatar
lucky131969
Originally Posted by Alex99
Hi all,
Whatever you do....don't post pics.....
Old Apr 29, 2010 | 09:56 AM
bobby777's Avatar
bobby777
Can you say 50 Ponys--
Old Apr 30, 2010 | 07:05 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Given the inconsistent quality of gasoline these days, that's why I changed my C-5's filter when the car was 4 years old, even though it had only 10-12,000 miles on it at the time. It's not that hard to do, and inexpensive (comparitively speaking) insurance.
My DD Camaro gets it's fuel filter changed every year.
Old Apr 30, 2010 | 09:12 AM
wcsinx's Avatar
wcsinx
Changed mine around 70k and literally dumped out a couple tablespoons of sludge from the input end. I didn't need to cut it open to know what the filter media looked like. And just like that, the startup hesitation I had disappeared.
Old Apr 30, 2010 | 10:04 AM
j84buick's Avatar
j84buick
Did you end up buying the special fuel line disconnect tool?
Old Apr 30, 2010 | 10:25 AM
wcsinx's Avatar
wcsinx
I did. They didn't work for crap. It's possible mine were just seized up with age. I ended up having to cut open the filter's collets with a Dremel.
Old Apr 30, 2010 | 10:29 AM
warlock007's Avatar
warlock007
?, i picked one up then put it on the lift but when i looked at the one in the car it looked to be fairly new. no rust, chrome was still clean, etc. i've had the car since Sept. 09 and i've put 2000 miles on it going over dirty roads, dirt road that leads to my house. I would think it would show signs of wear.
Is it normal to see it this way?
Old Apr 30, 2010 | 10:47 AM
76 VETTE's Avatar
76 VETTE
Old Apr 30, 2010 | 11:01 AM
wcsinx's Avatar
wcsinx
If you live in an arid area, I wouldn't expect to see much exterior wear. You might as well pull it. You have a new one, and it's the only way to know for sure.
Old Apr 30, 2010 | 11:21 AM
mickey_7106's Avatar
mickey_7106
can you post a part number?
Hi all,
Old Apr 30, 2010 | 11:28 AM
warlock007's Avatar
warlock007
ac delco GF822
Old May 1, 2010 | 01:52 PM
mickey_7106
ac delco GF822
thanks
Old May 2, 2010 | 12:17 AM
kawijames's Avatar
kawijames
Napa's p/n is FIL 3737. Napa online had them for $28 just a while back.
Old May 2, 2010 | 02:47 AM
LoneStarFRC's Avatar
LoneStarFRC
Wix 33737 $33.89
Old May 2, 2010 | 09:05 AM
omegac1's Avatar
omegac1
I have a 2003 with 100K miles but it haqs the filter in the tank. What should I do? I am sure its the original filter in the tank.
Old May 3, 2010 | 12:06 AM
LT1driver's Avatar
LT1driver
me too, what are we to do??
Old May 3, 2010 | 08:10 AM
81c3's Avatar
81c3
03's & 04's are supposed to be lifetime filters. I just did mine on my 02. The filter cost $123.00 from the dealer.
To Interesting fuel filter change discovery
