just got back from dyno and am pleased. not the most hp out there but will do for the street. had lpe due h/c package about 5 yrs ago but wanted more power. installed a comp cam and busted 400 rwhp. heads,intake and throttlebody ported,hp springs,and valves 3 angle cut,slp lt,ca and b&b exhaust. 3:42 gears w/2800 stall.cam specs 224 581 112.5. hope to run into the 11's with street tires.
11s will be easy with the auto. I had a similar setup with 414hp "unlocked" and ran consistent low 11s. Although I had Nitto RIIs, I never did a burn out and "drove it" off the line.
