Here is a good link.. This guy had a 1998 Coupe... Your Z06 will be exactly the same procedure.. Click on the first link inside of this link for more info.. Ican tell you that the #7 plug last plug on the drivers side is a tough one.. Make sure you have the right tools. There is a good chance you will break a plug wire or 2. They get really brittle and fragile after miles and miles.. This is the time to change them.. Remember if you do break one you will have to buy a set. The only way to buy one individual wire is through the dealership.. $34 a piece.. Rip off! Gene Cully is a GM parts dealer on this forum and had the Red GM hot wires for $57 a set (8).. Thats a steal of a deal... here is the link http://www.corvetteactioncenter.com/...nd-result.html
