224/234 cam?
Old May 1, 2010 | 04:36 PM
kjmj's Avatar
kjmj
Default 224/234 cam?
Sorry for another cam question. I tried the search with no success. Has anybody ever used this cam? I already have headers, and am thinking about this cam or a 224/228 I will also add 243 heads. This combo will be used on an automatic. Thanks for your help.
Old May 1, 2010 | 04:50 PM
slowtealz28's Avatar
slowtealz28
You plan on adding a stall converter? You can prob get away with the 223/228 on the stock one, I dont know about the 224/234. I would go with the 224/228 if I were you.
Old May 1, 2010 | 05:26 PM
Mr. Jones's Avatar
Mr. Jones
is that one of comp cams thumper cams?
Old May 1, 2010 | 05:31 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Lift??? LSA???
Old May 1, 2010 | 05:49 PM
kjmj's Avatar
kjmj
Originally Posted by 0331marine
lift??? Lsa???
581-598 114 224/234
601-612 112 224/228
Old May 1, 2010 | 06:00 PM
0331MARINE's Avatar
0331MARINE
Wow thats a bigger lift than my MS3 (237/242 .603 /609 112LSA) I would agree with slow that you are going to need a stall with the 224/234
Old May 1, 2010 | 06:10 PM
kjmj's Avatar
kjmj
I thought with only a 224 duration I would be fine with no stall?
Old May 1, 2010 | 06:20 PM
ctusser's Avatar
ctusser
I would go with less of a forward split unless that cam was specifically chosen. I would go with the 224-228 pattern if stock 243heads, and you are just trying to throw something together that's going to work well.
Old May 1, 2010 | 06:54 PM
slowtealz28
224/228 would be fine, but over 600 lift may be a problem. I would do 224/228 .581/.581 on a 114
To 224/234 cam?
