half shaft help
Old May 1, 2010 | 05:49 PM
feeder82's Avatar
feeder82
Default half shaft help
I've got some white grease slinging around the left rear wheel and suspension parts, it looks like white lithum grease, I cant find any holes in the boot, anybody had one of these cv's apart? is the grease inside white?
Old May 1, 2010 | 05:51 PM
83Camaro's Avatar
83Camaro
I couldnt find my hole in my cv boot, but it got grease ALL over. Im guessing thats 100% your problem, nothing else in that area can leak grease.
Old May 1, 2010 | 05:53 PM
feeder82's Avatar
feeder82
was it white grease? this is white
Old May 1, 2010 | 05:56 PM
LoneStarFRC's Avatar
LoneStarFRC
Unless the axle has been rebuilt by someone or replaced before no, the grease is not white. I would not recommend regular lithium grease in any case.
Clean all the areas you have seen and continue driving normally for a few days and check again, just to ensure you didn't run over something on the roadway that got slung all around by you tire/wheel. Even if you DO have a cut/tear/hole in one of your axle boots, they can sometimes be very hard to spot, depending on where it is. It doesn't take much as that axle spins up pretty good and the centrifugal force will "spin" the grease out.
Old May 1, 2010 | 06:22 PM
bumble-z's Avatar
bumble-z
Take your car out on the e/way for about a half hr. This will get the grease to a thinner state. Soon as you get home get under there w/correct lighting and spin your wheel slowly. Anywhere that looks remotly suspect, give it a sqeeze in that area. If it "milks out you know where it's coming from. Factory gease in the boots would be greenish,bluish to black looking. Hope this helps. Good luck.
Old May 2, 2010 | 01:08 AM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Mine had a pin hole in it. Did'nt actually find it until the shaft was out. Replaced the whole shaft, purchased in advance from supporting vender, as per cajundude write-up. Seemed easier than replacing the boot itself.
http://www.cajundude.com/outputshaftseal.htm
Old May 2, 2010 | 02:25 AM
83Camaro's Avatar
83Camaro
It wasnt white, but i dont see how it could be anything else
Old May 2, 2010 | 10:09 AM
feeder82's Avatar
feeder82
Thanks everyone, we found a pin hole, and if you squeezed it like a zit out came the grease
Old May 2, 2010 | 11:30 AM
postwhore's Avatar
postwhore
depending on how long and how much grease leaked out , a dab of silicone might fix it
Old May 2, 2010 | 12:37 PM
LoneStarFRC
Originally Posted by postwhore
depending on how long and how much grease leaked out , a dab from a Stridex pad might fix it
Bedder.
Old May 2, 2010 | 02:51 PM
postwhore's Avatar
postwhore
Originally Posted by LoneStarFRC
Bedder.
but seriously , I've seen people use silicone as a fix.
I wouldn't though
Old May 2, 2010 | 04:06 PM
feeder82's Avatar
feeder82
too late for patches, huge gross gob on the wheel that got this whole investigation started.
Old May 2, 2010 | 07:06 PM
Pro Street's Avatar
Pro Street
I had one come into the shop the other day with black electrical tape around the boot!
Old May 2, 2010 | 09:02 PM
postwhore's Avatar
postwhore
I had one come in with black electrical tape around the BRAKE LINE !
To half shaft help
