Baer/Eradispeed Two Piece Rotor Upgrade Problem
Old Sep 23, 2010 | 01:31 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Originally Posted by Blue LS1-LT1
Guys,
Does anyone know if the two piece, Baer Eradispeed set up will fit a base '99 coupe with factory N73 Magnesium wheels, and C5 Z06 calipers?
I am concerned about clearance, especially on the rears.
thanks!
I have the 14" Baer Eradispeed 2-piece rears on my N73 magnesiums in the rear with stock calipers. Very close, but no rubbing. Wheel weights should be applied further inboard, however.
Old Sep 23, 2010 | 01:47 PM
Blue LS1-LT1's Avatar
Blue LS1-LT1
thanks, 'Guy.
that's what Baer told me. it's always good to hear it from others with a smae set up as well.
What pads are you using?
Old Sep 23, 2010 | 02:47 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
N73 factory magnesium wheels?
I had 18" Chrome factory thin spokes.
Old Sep 23, 2010 | 07:51 PM
JPEAK's Avatar
JPEAK
Originally Posted by doublec4
Thanks guys,
The car is parked now for the winter, and I will have access to it again in the spring. I may take the brakes off to inspect everything again, however, from what I remember, the brackets are the same on both sides. They should be interchangable and symmetrical. Maybe I got a botched bracket on the one side, so I'll disassemble in the spring and look. Otherwise, I drove all summer with using hardened washers as spacers and I did not have any issues.
Parked for the winter, are you nuts???? LOL there is still at least 4-6, heck even 8 more weeks of great driving weather. I usually park it in mid november. See you in the spring.
Old Sep 24, 2010 | 12:49 PM
c5vetteguy's Avatar
c5vetteguy
thanks, 'Guy.
I went with new GM ceramic pads when I updated to the Eradispeed rotors. I also put in stainless braided lines, stainless Speedbleeders and a heavier brake proportioning spring. The spring applies more braking force to the rear and makes my C5 stop considerably flatter (less nose-dive). I reatained the stock calipers, which are fine for the type of driving I do.
Old Sep 24, 2010 | 01:02 PM
doublec4's Avatar
doublec4
Seeing as how nice its been out, the car is actually still on the road for another week to get the e-test done as well. However, it's actually my father's car and he's pretty uptight about it. I can't believe its going on 10 years old now, and it looks like show room condition clean.
Old Sep 24, 2010 | 10:01 PM
CTD's Avatar
CTD
Wow, I should have bitched out Bear 2 years ago, I thought I just had one of those anomalies.
I have easily accessible machine shop capability so I just had that problem bracket machined.
Sorry for your trouble, at times I wish I would post more so when you do the search there are suggestions. :o
Spacing the bracket with washers......I would not be able to sleep!
Here is where it is rubbing:
As you can see they are the stock calipers, and the rotor is stock thickness. How can I get the caliper to move back slightly? I don't want to space the spacer with washers. I shouldn't have to do that if the driver side was fine. I know the calipers slide.. I might try adjusting the pins? I'm at a loss here for why it would be like this.
Old Sep 25, 2010 | 02:53 AM
doublec4's Avatar
doublec4
Even if I had machine capabilities, I needed more material so machining wouldn't help. The washers don't really bother me. If I was using several washers to space the bracket a half inch or something I would be worried. One hardened washer won't make a difference. The car isn't tracked or anything.
Didn't think this would be a common problem, but apparently some others have experienced this as well... weird.
