Upgrading 1999 driveshaft
Old May 4, 2010 | 08:27 PM
Whistler's Avatar
Whistler
Default Upgrading 1999 driveshaft
I have to pull the drivetrain from my wife's car this weekend to do clutch hydraulics, so I may as well upgrade the smaller driveshaft while I have it out.
Do I need the whole 2001 +torque tube or can I do just the driveshaft inside?
Old May 4, 2010 | 08:58 PM
clif's Avatar
clif
St. Jude Donor '09-'10
I just had the propeller shaft replaced on my car. I got a larger shaft to handle more horsepower.
Old Shaft:
Old and New:
Other Ends:
New Shaft:
Updating the ends to accept larger bolts:
See the bolt difference?
Solid Rear Coupler:
Rear Drive:
Assembly:
Old May 4, 2010 | 09:55 PM
LoneStarFRC's Avatar
LoneStarFRC
In terms of likely total cost, yes. One things for sure, you can't just take a larger stock shaft and install it in your TT.
You can buy a good used assembly and (if needed) install two new couplers for less money that a custom shaft.
Old May 4, 2010 | 09:58 PM
LoneStarFRC
Originally Posted by clif
I just had the propeller shaft replaced on my car. I got a larger shaft to handle more horsepower.........
Is that some of Joey's handiwork Clif?
Old May 4, 2010 | 10:00 PM
clif's Avatar
clif
Not true! Can't you see that I have a larger shaft in mine?
clif's Avatar
clif
Yes, Joey did all the work! Mike Yeager spec'ed the shaft and bought it for me.
Old May 4, 2010 | 10:18 PM
LoneStarFRC
Oh, it's a beauty alright, no doubt. So is the labor for custom drilling, tapping, etc.
I think it likely that the OP's wife's car is a stocker.
Old May 4, 2010 | 10:21 PM
LoneStarFRC
I remember those pix from your posts in the past during your build. Lot's of nice work on your ride.
Let us hear what that new monster motor you're building puts out when you get it done.
Old May 5, 2010 | 11:25 PM
aleadfoot's Avatar
aleadfoot
I am pretty sure I toasted the bushing in my 99 torx tube today. Can I install a later model assembly in my 99? I am around 350rwhp and drive hard with upgraded heavy duty A4 but dont track the car (manually shift alot). Any modifications or will a later model bolt right up? New or used? If used should I change the bushings prior to install? Flex plate and convertor, while apart should I replace? Car has 70k miles. Any other tips or advice? Thank you
Old May 6, 2010 | 02:51 AM
cptinjak's Avatar
cptinjak
I don't see the point in replacing the TT just for the heck of it. If you are really worried about the driveline, maybe a diff brace and/or hardened output shafts.
If it fails, you WILL know. replacing something that might never fail, and only takes <3 hours to disassemble if it does, doesn't make sense to me. Spend your time/money elsewhere.
Just my opinion.
Jack
To Upgrading 1999 driveshaft
