Only one foglight..... pls help
Old May 4, 2010 | 11:34 PM
da_vato's Avatar
da_vato
Default Only one foglight..... pls help
Up until a few days ago both were working fine, then out of no where the drivers side quit working. Today I swithed the driver side element into the passenger side and worked fine. So I checked the voltage and I had voltage in the black wire (isnt that supposed to be a ground?) and the other wire had no power and no continuity to ground. Where does that harness run too physically? My first thought was a ground problem but I need to know where these wires run too. Fuses/relays are fine unless each one has its own.
Old May 4, 2010 | 11:39 PM
byronhunter's Avatar
byronhunter
Old May 6, 2010 | 06:25 AM
da_vato's Avatar
da_vato
thanks for the schematic but where are these wires physically? I cant really see where they venture off to.
Old May 6, 2010 | 03:12 PM
byronhunter
(1) Fuse Block - Underhood C3
(2) A/C Compressor Clutch
(3) S106
(4) S107
(5) Electronic Brake Control Module (EBCM)
(6) Cooling Fan - Left
(7) C107
(8) Brake Fluid Pressure Sensor
(9) Brake Differential Switch
(10) Brake Fluid Level Switch
(11) Windshield Washer Fluid Pump
(12) Repeater Lamp - Left
(13) Windshield Washer Fluid Level Switch
(14) G103
(15) SP101
(16) G101
(17) Headlamp Door Assembly - Left
(18) Fog Lamp - LF
(19) Secondary Air Injection (AIR) Pump
(20) S108
(21) Cooling Fan - Right
(22) Ambient Air Temperature Sensor
(23) Fog Lamp - RF
(24) Horn Assembly
(25) C100
(26) C113
(27) Headlamp Door Control Module C2
(28) Headlamp Door Control Module C1
(29) Headlamp Door Assembly - Right
(30) G102
(31) SP100
(32) Secondary Air Injection (AIR) Solenoid
(33) A/C Refrigerant Pressure Sensor
(34) Repeater Lamp - Right
(35) G108
(36) C102
(37) UHEC C6
(38) C148
(39) C140
(40) C150
To Only one foglight..... pls help
