cam opinions
Old Mar 16, 2002 | 11:09 PM
abraham's Avatar
abraham
Default cam opinions
what do you all think of going with the hammer cam on a 114 lsa for my A4 with 2400 converter?
Old Mar 17, 2002 | 03:50 AM
bparker's Avatar
bparker
Default Re: cam opinions (abraham)
MTI C1 (Hammer Cam) = .566/.566 .222/.222 112
:cheers:
Old Mar 17, 2002 | 08:10 PM
abraham's Avatar
abraham
Default Re: cam opinions (bparker)
Not that I think there should be but would it be a good option to go with the 222 on a 114 lsa for my A4.
Old Mar 17, 2002 | 08:24 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
I think a 222/222 114LSA cam would work very good for what you want to do.
Old Mar 17, 2002 | 08:54 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
MTI B1 221/221 114
Thunder Cam 220/220 114
114 lobe is the best for the A4!
Old Mar 18, 2002 | 02:16 AM
Touring's Avatar
Touring
Default Re: cam opinions (wallstAL)
Do any of you all have any 1/4 times before and after cam install?
Old Mar 18, 2002 | 07:20 AM
abraham's Avatar
abraham
Default Re: cam opinions (MattG)
Matt, can ARE cut the same cam as the hammer (same ramp rates etc...)but on a 114?
Old Mar 18, 2002 | 10:03 AM
MattG's Avatar
MattG
ARE does put a custom grind 222/222 114 .566/.566 cam in some customers' cars. I am not sure if the ramp rates are exactly the same but I assume they are very similar.
A friend of mine just had this cam 222/222 114 cam installed in his YANK 3500 w/3.42 A4 Stage II heads car in the Chicago area and loves the performance. He says it gives a nice sounding idle as well. This cam should also pass emissions without any problems.
[Modified by MattG, 9:18 AM 3/18/2002]
Old Mar 18, 2002 | 10:20 AM
TyVette01's Avatar
TyVette01
A friend of mine just had this cam 222/222 114 cam installed in his YANK 3000 A4 Stage II heads car in the Chicago area and loves the performance. He says it gives a nice sounding idle as well. This cam should also pass emissions without any problems.
how lumpy is the cam at idle? that sounds like an agressive cam that will still pass emissions. is this person on the forum so i can ask more questions as far as idle and power gains. :seeya
Old Mar 18, 2002 | 11:02 AM
TCC5's Avatar
TCC5
Default Re: cam opinions (TyVette01)
The cam that Matt is referring to (222/222 114 LSA)is actually my car. I had a brief drive after the H/C was installed this Saturday at Vettewrench and my first impression of the cam there is a noticeable offset idle (alittle lumpy) but not annoying at all. Initial test the car pulls hard. As for sound....someone who has h/c will notice it right away. At WOT...the car just SCREAMS! :D The car is still at Vettewrench for alittle more tuning with LS1 Edit. :cheers:
[Modified by TCC5, 9:06 AM 3/18/2002]
Old Mar 19, 2002 | 09:43 AM
TyVette01's Avatar
TyVette01
Default Re: cam opinions (TCC5)
tcc5, i have email you with some more questions. appreciate you and mattg for answering my question. :seeya
To cam opinions
