Windshield Wiper Stalk End Button Lost!
Old May 6, 2010 | 02:25 PM
gregm999's Avatar
gregm999
Default Windshield Wiper Stalk End Button Lost!
So I got in my car today, and as soon as I turned the key the wipers starting moving and spraying wiper fluid. I soon realized that the end button on the stalk that you press in to activate the washer fluid was missing. No idea how it came off. Searched frantically for it, but could not find it. Without the button in place, the wipers are moving frantically and the fluid keeps spraying out. What I need to do is manually stop this from happening, then pull the wiper fuse. However, I can't figure out how to stop the wipers from activating. Inside the stalk where the button was, I can see a few metal terminals. There must be a way to manipulate these so that I can temporarily stop the wipers, so that they'll go back into resting position. Then I can pull the fuse and be done with it for now, until I find the button or get a new one. Anyone know how to do this?
Old May 6, 2010 | 02:56 PM
87SAM's Avatar
87SAM
Timing, just pull the fuse when they are on the way down.
Old May 6, 2010 | 03:13 PM
TK6's Avatar
TK6
You could try pulling the two terminals apart with your fingers and wedging a piece of paper between them to shut off the wipers, then pull the fuse?
Old May 6, 2010 | 03:25 PM
gregm999's Avatar
gregm999
The problem is I need them to recess down to their resting position. If I pull the fuse while they're at the lowest position, they still aren't in the resting position tucked on the bottom of the windshield.
Old May 6, 2010 | 03:26 PM
gregm999's Avatar
gregm999
Is this what causes the switch to stop the wipers/fluid? I've tried pulling and pushing those terminals all over the place to no avail. So just pushing them apart should do it?
Old May 6, 2010 | 04:09 PM
87SAM's Avatar
87SAM
I don't get it, what's the big deal about the resting position? They can rest once you replace the switch.
Old May 6, 2010 | 04:24 PM
gregm999's Avatar
gregm999
I'd rather not have the wipers sticking up into the windshield for however long it takes to replace the switch. Doesn't look right at all.
Old May 6, 2010 | 10:25 PM
byronhunter's Avatar
byronhunter
if I'm reading the Schematic correctly, if you unplug the W/S Wiper Switch, they will park in the correct position.
C219 (6 cavities)
Instrument panel harness to steering column harness, LH side of the steering column attached to the instrument panel lower beam
Dark Green
Grey
Yellow
Purple
Pink
Old May 7, 2010 | 09:02 AM
Blue Angel's Avatar
Blue Angel
SUBSCRIBING!
I got into a pretty fierce screaming match with my significant other last summer on the way to a wedding (go figure...), and part of me taking my frustration out involved pounding my hand on the steering wheel.
Somehow my pinky finger slammed into the end of the wiper stalk and ejected the fluid button... immediately the wipers came on with full fluid application and stayed that way until I got it onto the side of the road and shut it off. This improved my mood dramatically, as you can immagine -
I got it to stop by putting little pieces of plastic from a coffee cup lid (thanks Timmys!) in between the little copper/brass terminals inside the stalk. I found the button but the spring vanished... it still sits this way today.
I'm interested in the fix - i.e. where the heck can I get a new wiper stalk? The new part from GM Partshouse was about $160 if I remember right, too rich for my blood!
I can't believe I found a thread with someone else having this same problem!
Old May 7, 2010 | 10:37 AM
gregm999's Avatar
gregm999
Originally Posted by Blue Angel
SUBSCRIBING!
I'm in the same boat now. Found the button, but cannot locate the spring anywhere. It's not much of a concern to me now, as I used the washer fluid maybe once in the year I've owned the car. With the button in place, the washer fluid and wipers are no longer activated, so that is fine with me. I just have to be careful not to touch the button, or it'll indent in, and that will activate the fluid, then you can't get the button out without a very thin screwdriver. I'll continue to look for the Spring, as it has to be in there somewhere, but other then that I won't go out of my way to fix it.
Old May 7, 2010 | 05:55 PM
RSchleder's Avatar
RSchleder
Any good hardware store sells small springs. It would seem to me that you could pick one up pretty easily.
Old May 8, 2010 | 09:36 AM
Eric Reeves's Avatar
Eric Reeves
It's two springs. Same thing happened to me last summer.
Old May 10, 2010 | 03:54 PM
Blue Angel's Avatar
Blue Angel
TWO springs? Oh man... I'm done!
Old May 11, 2010 | 01:59 PM
wfdlt8's Avatar
wfdlt8
I used the springs out of a bic lighter worked perfect.
Old May 17, 2010 | 08:51 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Originally Posted by ISUCorvette4Life
Any one know where you can buy a new button?!
The button is part of the wiper control switch. It's not sold separately as a part.
You could try a salvage yard to find one. Other GM cars may have the same washer button on the wiper control switch.
Old Apr 30, 2011 | 04:53 PM
Clamshell's Avatar
Clamshell
This forum rocks! The bic lighter spring works perfect. I will say that you have to cut the spring from the lighter smaller than what comes out of the lighter and even smaller than the original spring. I found one of mine but not the other. So, I ended up cutting the spring from the lighter to the same size as the one I found. I popped the springs in and found that the button popped right out because the bic spring has more tension than the original. So, I ended up cutting another piece of the lighter spring about 1 centimeter smaller than the orignal wiper stalk spring. Works like a champ. Thanks to this forum I have saved myself 160 dollars in parts and 5 hours worth of my time installing a new stalk!
Also, a temporary fix for separating the terminals inside the stalk is to use a two prong power outlet plug cover.
Old Apr 30, 2011 | 05:02 PM
JropTop's Avatar
JropTop
I have one for parts if interested!
To Windshield Wiper Stalk End Button Lost!
Old Apr 30, 2011 | 05:20 PM
LoneStarFRC's Avatar
LoneStarFRC
AC Delco D6363D
Complete assembly
Amazon $110.xx
Old May 1, 2011 | 07:31 AM
1996Z15's Avatar
1996Z15
I had this same thing happen to me but I was fortunate enough to find both springs and the button. Replaced everything but it continued to happen; I think once the button pops out once it must be more likely to pop out again.
Purchased a used wiper stalk from a vendor on the forum for something like $55.00. I was going to try and replace the whole assembly but, it looked more involved than I wanted to try and tackle. Popped out the button from the replacement stalk, installed it in my car and haven't had a problem since (knock on wood).
Old May 8, 2011 | 02:18 PM
z06fred1's Avatar
z06fred1
when my button popped out, it hit my wife in the cheek. she was mad, I almost had a wreck while laughing. easy to replace, just becareful with the steering column covers, they are fragile and 60 bucks each.
