drivers door remote won;t open
Old May 7, 2010 | 08:57 AM
jimbo409's Avatar
jimbo409
Default Passenger door remote won;t open
My 2000 Passenger door won't open with the remote control. I tried both remotes and re syronized both remotes. The drivers door works and opens fine just the passenger door wont work with the remote. Has anyone else had this problem and does anyone know what could be wrong before I take it to the dealer. Thanks Jimbo
Old May 7, 2010 | 09:11 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
When you say you resynchronized both of your remotes was that by standing close by to the car and pushing/holding the lock/unlock buttons at the same time for 15-20 so seconds until the car beeped or made some noise?
If so there is a procedure to resync via the DIC that is described in your owners manual. This procedure is a little more involved than just holding down the two buttons.
Good luck and hope this helps!
Chuck
Old May 7, 2010 | 09:23 AM
jimbo409's Avatar
jimbo409
Default remote
Yes I stood next to the car and press the lock and unlock button until the horn beeped.
Old May 7, 2010 | 11:01 AM
lucky131969's Avatar
lucky131969
Originally Posted by jimbo409
My 2000 drivers door won't open with the remote control. I tried both remotes and re syronized both remotes. The drivers door works and opens fine just the passenger door wont work with the remote. Has anyone else had this problem and does anyone know what could be wrong before I take it to the dealer. Thanks Jimbo
The title of your thread title states: "drivers door remote won;t open", and you state in the thread : "The drivers door works and opens fine just the passenger door wont work with the remote"
Which is it?
Old May 7, 2010 | 12:44 PM
76 VETTE's Avatar
76 VETTE
My 01 Z pass. door will not open with remote but driver door will.
Old May 7, 2010 | 12:55 PM
lucky131969
Just curious...what is the "auto lock" set to in the DIC?
1) Auto unlock driver
2) Auto unlock both
3) Auto unlock off
Old May 7, 2010 | 12:59 PM
76 VETTE's Avatar
76 VETTE
2) Auto unlock both
3) Auto unlock off
I will go look nw to see.
Old May 7, 2010 | 01:06 PM
76 VETTE's Avatar
76 VETTE
Auto lock was off.Reset to on and still remote does not open pass.
Old May 7, 2010 | 01:43 PM
lucky131969
On? You have three choices: driver, both, or off.
Old May 7, 2010 | 01:51 PM
76 VETTE's Avatar
76 VETTE
Hope jimbo doesn't flame me for hijacking.Not trying to.Mine only has 2 options:auto lock on or off.
Old May 7, 2010 | 01:54 PM
76 VETTE's Avatar
76 VETTE
Maybe different on coupe than a Z
Old May 7, 2010 | 01:58 PM
lucky131969
It's not. I misspoke. The setting is for "auto unlock". It's in your owners manual under "Driver Information Center".
Old May 7, 2010 | 02:05 PM
76 VETTE's Avatar
76 VETTE
Ok,thanx for trying to help lucky
Old May 7, 2010 | 02:12 PM
lucky131969
Try that setting. I'm not certain if it will have any effect. Also pull your codes.
Old May 7, 2010 | 03:15 PM
jimbo409's Avatar
jimbo409
I also went to the dci and the setting is auto on. I only have auto on and drivers on and auto off. I tried all different settings and the passenger door still won't open Thanks Jimbo
Old May 7, 2010 | 03:18 PM
lucky131969
any codes?
Old May 7, 2010 | 03:29 PM
2KFRC5's Avatar
2KFRC5
Are you pushing the unlock button twice? On mine, 1 push unlocks the driver's door, 2nd push unlocks the passender's door.
To drivers door remote won;t open
Old May 7, 2010 | 07:55 PM
Bakersfield's Avatar
Bakersfield
Do they lock/unlock from the control panel inside the car? If not, then your problem is not in the FOB but in the door control module. I have an extra 97-2000 door control module, PM me for detail.
Old May 7, 2010 | 11:28 PM
ISeeRed's Avatar
ISeeRed
What he said! Make sure you're pushing the unlock button twice for the passenger door.
Old May 8, 2010 | 09:01 AM
jimbo409's Avatar
jimbo409
I have pushed the remote 2 or more times and nothing, I now think it might be the door control module like Bakersfield mentioned. How hard a job to put a new door control module in. Thanks Jim
