TAC/PCM/LS3 TB confusion?!?!
The car starts and idles fine, it takes some throttle response fine. However, if you rev the engine a few times, or with the engine off, and car keyed-on and take it to WOT, the blade moves, but eventually I get the Reduced Engine power, from either p1515 or p1516 (had it happen both ways)
I have seen from some lots of searching some random mentionings that the TAC module needs swapped out? But nothing definitive, and doesnt seem to be common. I am definitely not the first to put an ls2/ls3 tb on my car, so what gives? Is it the TAC? Is it my casper electronics wiring harness adapter (the pinout seemed to be right though, unless a wire is loose?)
In my case the caspers electronics adapter harness was faulty (+5V and ground wires swapped.... ouch
)Details here:
http://forums.corvetteforum.com/c5-t...brand-new.html
Lucky131969 might be able to help you.
Check that the brown and yellow wires are not reversed and that all connexions are tight for the position sensor 1 and 2.
Goos luck
