Thinking about adding NO2
Old May 11, 2010 | 04:33 PM
Leo001's Avatar
Leo001
Default Thinking about adding NO2
I have been craving more power lately. I am wondering about Nitrous Oxide, seems to a good choice as I dont need it all the time, and I dont want to spend thousands on upgrades right now (thats a whole nother discussion, upgrade motoe to big cubic inch, supercharger or just get a C6) anyway how much nitrous is "safe" and who has the best system.
Old May 11, 2010 | 04:35 PM
lucky131969's Avatar
lucky131969
http://forums.corvetteforum.com/c5-f...on-nitrous-86/
Old May 11, 2010 | 05:47 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Well it all depends on what you want and your power expectations. Do you have any current modifications to your car? I will say on a stock block car a 100-150 shot tends to be the norm for a simple nitrous application. As for safe you can go higher as long as you have the fuel and tuning right.
I will add I personally started off my nitrous mods with a 300 dollar dry kit and a FJO controller. I currently have progressed though into a direct port setup with a stand alone fuel cell and extensive electronics and controls (around 3k worth of stuff).
Old May 12, 2010 | 02:23 AM
billymz28's Avatar
billymz28
personally Im staying at a 100 shot until I upgrade fuel pumps. And just get all you safety devices inline. Pull 2 degrees for every 50 shot and ad some n20 plugs and you should be good. I personally like n20 outlets plate kit. Be prepared to be addicted.
Old May 12, 2010 | 09:20 AM
Leo001's Avatar
Leo001
"Normal mods" low restriction exhaust and cold air kit. I'm looking for that occational "shot" with out spending yons of $$$ so it sounds like 100hp system is "safe" any recomenfations on which system??
Old May 12, 2010 | 11:41 AM
Sigforty's Avatar
Sigforty
I would recomment a 100 hp wet shot from Nitrous outlet. If you wanted to cut down on parts and upgrade your injectors you could do a dry kit instead of the wet. I like all there stuff and Dave is active on the forums as well as his employees. I personally run all his stuff.
To Thinking about adding NO2
