Alternative oil press location
Old May 12, 2010 | 02:21 PM
Castrellon's Avatar
Castrellon
Default Alternative oil press location
Read this :http://forums.corvetteforum.com/c5-t...-relocate.html
Says you need a M16x1.5. Is there a front oil plug? I thought I had read there was one under the alternator. Am I correct? Is it the same size? I need to check my oil pressure to see if it's a bad sensor or if my oil pressure really is coming up to slow. I was going to go to my local speed shop and see if they had that autometer part # but don't don't want to buy it if it's not what I need to just check with my mechanical gauge.
Old May 12, 2010 | 02:28 PM
lucky131969's Avatar
lucky131969
Old May 13, 2010 | 02:26 AM
Castrellon's Avatar
Castrellon
Is this referring to post #59? That inverted hex plug left front of the block? 16x1.5, right?
To Alternative oil press location
