Help, Code comes up "reduced engine power and kills my car!!
Old May 14, 2010 | 09:46 PM
2004TTZ06's Avatar
2004TTZ06
Default Help, Code comes up "reduced engine power and kills my car!!
I have twin turbo's on my car with a Honda Civic alternator on my car that is supposed to be the culprit. The alternator puts out the right amps, but I will be driving and at any given time the code comes up on display "reduced engine power and kills the car. I have to reset the codes with my scan tool before it will crank up again. Any ideas how to bypass this problem? Thanks!
Old May 14, 2010 | 10:01 PM
minitech's Avatar
minitech
Post the codes so more people can give some help.
Is your throttle position sensor wire loose? The wire on the throttle body opposite the actuator motor.
Old May 14, 2010 | 10:12 PM
lucky131969's Avatar
lucky131969
A honda alternator....is this a joke?
Old May 14, 2010 | 11:06 PM
2004TTZ06's Avatar
2004TTZ06
If you read the post on the PTK turbo kit, all of the kits intalled required a Honda alternator because it is smaller than the origional and has to be relocated. An alternator is an alternator, did'nt know that one alternator did anything different than the other?
Old May 14, 2010 | 11:08 PM
2004TTZ06's Avatar
2004TTZ06
Ill have to check that wire out Monday and post the codes. I really appreciate the help!
Old May 14, 2010 | 11:36 PM
2004TTZ06's Avatar
2004TTZ06
Some post are showing check the door looms, and grounds, I have relocated my battery to the rear compartment in the car, sounds like a lot of things could be the issue, anyone local to lufkin or houston texas that could re$olve my problem?
Old May 15, 2010 | 12:30 AM
Jnape's Avatar
Jnape
The C-5 Alternator has an output to the PCM for all kinds of diagnostics. I would expect charge fault errors on the DIC and not reduced engine power though.
Old May 15, 2010 | 01:06 AM
lucky131969
So you think all alternators are the same? They are not even all the same between C5's.
Old May 15, 2010 | 09:35 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If you're getting a P0068, the fix will be found in the tuning.
If not, post what codes you are getting.
To Help, Code comes up "reduced engine power and kills my car!!
