column lockplate removal
Old May 16, 2010 | 12:47 AM
fatbillybob's Avatar
fatbillybob
Default column lockplate removal
Anyone got pics or a tutorial of how to exactly remove the column lockplate?
Thanks!!
Old May 16, 2010 | 08:27 AM
dougbfresh's Avatar
dougbfresh
Why remove it?
Old May 16, 2010 | 10:18 AM
fatbillybob
1) I'm a racecar now and safer to not have this function
2) don't need turn signal I'm a race car
3) I thought the GM fix to the locked column was to remove the lock plate so the acturator pin would slide in and out without interferrence thus the actuator would send proper signals to the BCM thus fixing the column lock issue sometimes combined with harness K install or thundermountain racing CLB.
Old Jun 11, 2010 | 09:20 AM
fattboa's Avatar
fattboa
Cruising
Will removing the lock plate negatively affect anything else? I'm contemplating doing it
If anyone could answer this, I would be grateful
Old Jun 11, 2010 | 09:26 AM
dougbfresh's Avatar
dougbfresh
I seem to recall there are a couple of specific tools needed to disassemble the steering column-might not want to try this at home.
Old Jun 11, 2010 | 10:51 AM
fattboa's Avatar
fattboa
Cruising
First of all, thank you for the quick reply.
I would not try this at home, rather a garage and hopefully a Corvette-centric mechanical or at least someone with an extensive GM-related steering column background.
I have read that a special lockplate-like thing is supplied with the GM harness, its purpose is to cancel or at least something related to the turn signals.
However I may have traced my problems to a faulty ignition cylinder or at least key, code B2723, so perhaps after fixing that problem the column will unlock and I will immediately order a CLB from overseas.
Once again, I appreciate your quick response
Old Jun 11, 2010 | 11:41 AM
fattboa's Avatar
fattboa
Cruising
8Vette7,
Thank you for responding about the lock plate.
Since the car was shipped from the USA new and "the" official dealer does not perform any recalls whatsoever, it does not have the K-Harness.
The battery may be an issue as well as the ignition cylinder. I will test these tomorrow and see what happens
Reading the column lock sticky, I understand that you responded to these type of questions quite a lot of times and I would like to thank you for taking your time once again to reply.
To column lockplate removal
