3.42 differential
Old May 17, 2010 | 03:50 PM
Sick C5's Avatar
Sick C5
Default 3.42 differential
I'm going to swap my 2.73 for a 3.42. Should I go with a 1-rib or a 3-rib? What should I expect to pay?
Old May 17, 2010 | 09:21 PM
rodsvet's Avatar
rodsvet
I just got a brand new zo6 3:42 from Gene Culley @ GMParts. I got in 3 business days right to my door. It's a 3 rib for strength. Price with shipping and no tax is $1404.27. You might find used but if it's a 3:42 it's probably been beat on unless you really know who you are getting it from. Call Gene, he will treat you right!! Rod
Old May 18, 2010 | 04:27 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
3 rib case is stronger. The Z06 differential comes with shot-peened gears.
Old May 18, 2010 | 08:53 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
I'm thinking about 3.42's also, however I have an auto and 3.15's now. Do you guys think I will notice the difference?
Old May 18, 2010 | 09:03 AM
bumble-z's Avatar
bumble-z
I agree. Put a new one in. That way you're not opening the door for problems, more $$$$ and down time. Good luck.
Old May 18, 2010 | 09:07 AM
bumble-z's Avatar
bumble-z
No, it wouldn't be worth the time or money . If however you're doing your own labor, then maybe I would consider. Good luck.
Old May 19, 2010 | 07:50 PM
99vetteran's Avatar
99vetteran
i bought a used 3.42, I broke mine. I paid $500 for a 39,000 mile diff. I also purchased a left hardened output shaft from dte as I plan to take mine to the track again. If you do buy one used, make sure it low mileage, if you can't find one then buy a new one. I had a high mileage one I took to the track and it lasted 2 passes and broke on the third. Also took out the tranny output shaft. Do it right.
Old May 19, 2010 | 08:14 PM
Chuck01's Avatar
Chuck01
I think you will and if you do a TC at same time you will be very happy.
Old May 19, 2010 | 08:54 PM
paint it black vette's Avatar
yes. but youll notice it more with 3.73 and a stall. gas mileage goes down but the grin gets bigger and who bought a vette to go slow and worry about gas?"
Old May 20, 2010 | 10:19 AM
Mike Mercury's Avatar
Mike Mercury
http://www.tim-yvonne.com/mikemercury/342.htm
and add this:
http://forums.corvetteforum.com/c5-t...-da-floor.html
To 3.42 differential
