What is the size of front rotors?
I've found infos from 12.6" to 12.9".
I ask because I'd like to install high quality rotors, 2- piece,
but the ones that I'm looking at are 332 mm - 13.07"
Does anybody know if it's possible to put this size rotors under
stock calipers?
I have a C4 vette, but with C5 front brake upgrade.
stock calipers?
The 332 mm rotors are for C6 Z51 cars, you need 325 mm X 32 mm rotors for a stock C5 set up. Stoptech makes a direct replacement two piece for the C5 - Stock #81-180-9911 - $650 per pair. If you find them cheaper let us all know. Performance AFX also make a set for the C5 - $624 per pair, but I don't know the stock numbers on those.
